Hello folks. I'm glad to finally join the forum, I've noticed there are some true CAD wizards here ;).
I have a bit of a complex problem I can't quite solve myself right now. I need to automate/shortcut the Dataextraction wizard in AutoCAD using a LISP program. Preferably I'd like to do this in a way that can be used in LT as well. Specifically (for the filters), I need the Dataextraction function to count the number of polylines on a specified layer, while extracting objects from blocks, from a selection that I can either make before I run the program or during the operation. I then need the count of polylines to output to a table inside of CAD, the same way Dataextraction does. Ideally, I'd like to have the program autoselect the region for me by referencing the area within a specific rectangular polyline/block that will remain the same across all of my CAD files via a template.
I've done some tinkering with LISP programs and have one that can select everything within the bounds of a polyline, but it's not enough for this. Any help would be much appreciated.
Welcome to CADTutor. :)
Your profile says that you are using LT. is that correct?
I ask because, as I understand it, LT is not Lisp compatible.
If your profile is inaccurate, please correct it, as nobody is likely to help you create a lisp which you won't be able to use.
For good reason.
For good reason.
Thank you for the hint. I typically use LT, but I have access to the full version of CAD as well.
Ok some simple answers using ssget in a lisp you can add pline & layer filter and sslength is how many. Adding to table again no problem. Again Again within a predefined area no problem.
; an example
(setq win (list 0,0 100,100)) ; window size also see help for CP WP
(setq wbox (list 0,0 100,0 100,100 0,100))
(setq ss (ssget "W" '(0 0) '(100 100) (list (cons 8 "layername")(cons 0 "LWPOLYLINE"))))
(alert (strcat "There is " (rtos (sslength ss) 2 0) "Plines"))
