tmelancon Posted June 6, 2016 Posted June 6, 2016 Have a neat little LISP that removes prefix or suffix. Currently it is written to remove anything before or after a "dash" INCLUDING THE DASH. I need it to keep the dash. Thanks in advance. ;; ;; By Don Ireland ;; ;; Takes two arguments: A String to search for and a string to search in. ;; Usage: (charfind "ST" "TEST") ; This will return 3. ;; ;; Example: (if (> (setq pos (charfind "S" "TEST")) 0)(princ "Found the letter S at position: " . pos)(Princ "One or both search parameters was blank")) ;; ;; Return Values: ;; -1 = character not found within given string. ;; -2 = Search string is empty. (srch) ;; -4 = Test String is empty. (str) ;; -6 = Search String and Test String are both empty. (defun strfind(srch str / pt pt2 cnt) (setq cnt 0 pt 0 pt2 nil) (if (EQ (strlen srch) 0) (setq pt -2)) (if (EQ (strlen str) 0) (setq pt (+ pt (- 0 4)))) (if (EQ pt 0)(setq pt -1)) (while (and (< pt 0) (> (strlen str) 0)(< cnt (strlen str))) (if (eq srch (substr str (setq cnt (1+ cnt)) (strlen srch)))(setq pt cnt)) ) (setq pt2 pt) ) (defun remTxt(ba) (setq ent (ssget '( (-4 . "<OR") (0 . "TEXT")(0 . "MTEXT")(8 . "*DATA") (-4 . "OR>") )) ) (setq cnt -1) (repeat (sslength ent) (setq cent (entget (ssname ent (setq cnt (1+ cnt))))) (setq cur (cdr(assoc 1 cent))) (setq pos (strfind "-" cur)) (if (EQ ba 1) (setq new (substr cur 1 (1- pos))) (setq new (substr cur (1+ pos) (strlen cur))) ) (setq cent(subst (cons 1 New) (cons 1 cur) cent)) (entmod cent) ) ) (defun c:remA() (remTxt 1) ) (defun c:remB() (remTxt 0) ) Quote
pkenewell Posted June 6, 2016 Posted June 6, 2016 if you want to do both the Prefix and the Suffix, change the following lines: (if (EQ ba 1) (setq new (substr cur 1 (1- pos))) (setq new (substr cur (1+ pos) (strlen cur))) ) to: (if (EQ ba 1) (setq new (substr cur 1 pos)) (setq new (substr cur pos (strlen cur))) ) Quote
Lee Mac Posted June 6, 2016 Posted June 6, 2016 Try the following: (defun remtxt ( f / e i s x ) (if (setq s (ssget "_:L" '((0 . "TEXT,MTEXT") (1 . "*`-*")))) (repeat (setq i (sslength s)) (setq e (entget (ssname s (setq i (1- i)))) x (assoc 1 e) ) (entmod (subst (cons 1 (f (cdr x) (1+ (vl-string-search "-" (cdr x))))) x e)) ) ) (princ) ) (defun c:rema nil (remtxt (lambda ( s p ) (substr s 1 p)))) (defun c:remb nil (remtxt (lambda ( s p ) (substr s p)))) Quote
tmelancon Posted June 6, 2016 Author Posted June 6, 2016 Works really sweet.. I was on to something earlier, I removed the 1- but didnt remove the () that was associated with it. Also, two more things, I am getting lists showing up in the command line, I tried using CMDECHO and that didnt seem to work. Any ideas? Also the other thing I was curious about is how would I write for the SSGET to automatically get TEXT on DATA layer and perform this operation.. instead of user selected TEXT. Thanks in advance for your great knowledge! I tried: (setq ent (ssget "X" (LIST (CONS -4 "<OR") (CONS 0 "TEXT") (CONS 0 "MTEXT") (CONS 8 "*DATA") (CONS -4 "OR>") ) ) ) ..nothing. Quote
tmelancon Posted June 6, 2016 Author Posted June 6, 2016 Hey guys thanks for chiming in really appreciate it. Lee I was able to get yours to work the way I needed it, so I guess I will be archiving the other one. This is what worked: (defun remtxt ( f / e i s x ) (if (setq s (ssget [color=red]"X"[/color] '((0 . "TEXT,MTEXT") (1 . "*`-*") [color=red](8 . "*DATA,*HIGH")[/color]))) (repeat (setq i (sslength s)) (setq e (entget (ssname s (setq i (1- i)))) x (assoc 1 e) ) (entmod (subst (cons 1 (f (cdr x) (1+ (vl-string-search "-" (cdr x))))) x e)) ) ) (princ) ) (defun c:rema nil (remtxt (lambda ( s p ) (substr s 1 p)))) (defun c:remb nil (remtxt (lambda ( s p ) (substr s p)))) Quote
pkenewell Posted June 6, 2016 Posted June 6, 2016 LOL Lee Beat me to the Punch (along with the most efficient code), but here's my version anyway FWIW with complete error handling: (defun RemTxt (ps / _Massoc cnt en Remtxt_error ss sp st) (vl-load-com) ;; Error Handling (defun Remtxt_error (msg) (if (not (wcmatch (strcase msg T) "*break*,*cancel*,*quit*,*exit*")) (princ (strcat "\nError: " msg "\n")) (princ "\nProgram Aborted.\n") ) (vla-EndUndoMark (vla-get-activedocument (vlax-get-acad-object))) (and err:bak (setq *error* err:bak)) ) ;; Nested Function to get Multiple repeating DXF codes. (defun _Massoc (el dxf) (vl-remove-if 'null (mapcar (function (lambda (x)(if (= (car x) dxf) x nil))) el) ) ) (setq err:bak *error* *error* Remtxt_error) (vla-StartUndoMark (vla-get-activedocument (vlax-get-acad-object))) (princ "\nSelect TEXT or MTEXT: ") (if (setq ss (ssget '((0 . "TEXT,MTEXT")))) (repeat (sslength ss) ; Get the Entity Name (setq en (entget (ssname ss (setq cnt (if cnt (1+ cnt) 0))))) ; Check for long strings (if (assoc 3 en) (setq st (strcat (apply 'strcat (mapcar 'cdr (_Massoc en 3))) (cdr (assoc 1 en)) ) ) (setq st (cdr (assoc 1 en))) ) ;; Get the "-" char. pos. (setq sp (vl-string-position 45 st)) ;; If a dash exists, truncate based on the flag. (if sp (setq ns (if ps (substr st 1 (1+ sp)) (substr st (1+ sp)))) (princ "\nNo Dashes found in String.") ) ;; Update the entity. (setq en (subst (cons 1 ns) (assoc 1 en) en)) (entmod en) ) ) (vla-EndUndoMark (vla-get-activedocument (vlax-get-acad-object))) (setq *error* err:bak) (princ) ) (defun c:remA()(RemTxt T)) (defun c:remB()(RemTxt nil)) Quote
pkenewell Posted June 6, 2016 Posted June 6, 2016 (edited) Here is another version using Yours and Lee's Filtering and using ActiveX to change the Text String (a bit less code from my previous): (defun RemTxt (ps / _Massoc cnt en ss sp st) (vl-load-com) ;; Error Handling (defun Remtxt_error (msg) (if (not (wcmatch (strcase msg T) "*break*,*cancel*,*quit*,*exit*")) (princ (strcat "\nError: " msg "\n")) (princ "\nProgram Aborted.\n") ) (vla-EndUndoMark (vla-get-activedocument (vlax-get-acad-object))) (and err:bak (setq *error* err:bak)) ) (setq err:bak *error* *error* Remtxt_error) (vla-StartUndoMark (vla-get-activedocument (vlax-get-acad-object))) (princ "\nSelect TEXT or MTEXT: ") (if (setq ss (ssget "X" '((0 . "TEXT,MTEXT")(1 . "*`-*")(8 . "*DATA,*HIGH")))) (repeat (sslength ss) ; Get the Entity ID (setq en (ssname ss (setq cnt (if cnt (1+ cnt) 0))) st (vla-get-TextString (vlax-ename->vla-object en)) sp (vl-string-position 45 st) ns (if ps (substr st 1 (1+ sp)) (substr st (1+ sp))) ) ;; Update the entity. (vla-put-TextString (vlax-ename->vla-object en) ns) ) ) (vla-EndUndoMark (vla-get-activedocument (vlax-get-acad-object))) (setq *error* err:bak) (princ) ) (defun c:remA()(RemTxt T)) (defun c:remB()(RemTxt nil)) Edited June 6, 2016 by pkenewell Quote
