PB80 Posted June 12, 2016 Posted June 12, 2016 I'm running Autocad 2017 on an Asus ROG 17" (specs below) and even simple 2d cad work is sluggish. The mouse stalls for a second or commands take a second to kick in after hitting enter. SOOOOOOO annoying because I have a deadline. Guys, I've tried enabling/disabling hardware accelaration, I've updated the graphics card firmware.... and nothing. I want to cry. Please help! What am I doing wrong? Why the hell did I buy this powerful machine? For what? I dont game!! :cry::cry: Processor 2.6 GHz Core i7-4720HQ RAM 16 GB DDR3 Memory Speed 1600 MHz Hard Drive 1024 GB HDD 5400 rpm Graphics Coprocessor NVIDIA GTX965M 2GB GDDR5 Chipset Brand NVIDIA Card Description dedicated Graphics Card Ram Size 2000 MB Quote
CAnnondale Posted June 12, 2016 Posted June 12, 2016 WOW! Is these how? Powerfull you need you PC in oder to run AutoCAD now. sent by Wehlee Quote
Dadgad Posted June 12, 2016 Posted June 12, 2016 Welcome to CADTutor PB80. Might it be a commandline setting, such as the commandline Prompt delay? Quote
Dana W Posted June 12, 2016 Posted June 12, 2016 Is the Nvidia video card enabled as the system default? When I installed my card, I found I had to enable the thing myself. Who'd a thunkit? Quote
f700es Posted June 12, 2016 Posted June 12, 2016 Is the Nvidia video card enabled as the system default? When I installed my card, I found I had to enable the thing myself. Who'd a thunkit? It's a laptop, "GTX965M" The "M"means mobile. Quote
PB80 Posted June 12, 2016 Author Posted June 12, 2016 It is. I tried toggling it too and nothing changed. Quote
PB80 Posted June 12, 2016 Author Posted June 12, 2016 Is the Nvidia video card enabled as the system default? When I installed my card, I found I had to enable the thing myself. Who'd a thunkit? How could I check to see if it's actually enabled? Quote
Dana W Posted June 14, 2016 Posted June 14, 2016 How could I check to see if it's actually enabled?Through the Nvidia console dialog, or through Windows control panel device manager. Enable and set as default. I don't remember the details. Four years ago I had a GTX650 or some such Nvidia card installed in my laptop. Once I discovered I had not yet actually turned it on, I was good to go. bought the computer new with the card in it from Dell, and they apparently didn't really finish up the install. Quote
samifox Posted June 15, 2016 Posted June 15, 2016 1.Make sure u install the last sp. Reset ur sysvar.3.stop crying Sent from my Lenovo PB1-770M using Tapatalk Quote
CAnnondale Posted June 15, 2016 Posted June 15, 2016 1.Make sure u install the last sp. Reset ur sysvar.3.stop crying Sent from my Lenovo PB1-770M using Tapatalk If I am not mistaken. The TS is not so EXPERT AS YOU DO. so please do not be so sarcastic. sent by Wehlee Quote
samifox Posted June 15, 2016 Posted June 15, 2016 If I am not mistaken. The TS is not so EXPERT AS YOU DO. so please do not be so sarcastic. sent by Wehlee Just used some humor and I was reading it with my phone so couldn’t get into details Anyway…. 1.make sure to reset system variables, All Programs > Autodesk > Autocad > Reset Autocad. 2. service packs are a little software Autodesk release after a new version launch in order to fix bugs. 3.make sure no AEC objects and proxies are existing in your drawing. Etransmit the drawing, and in the profile make sure to choose to convert to autocad with AEC exploded. 4.if you invest in a powerful pc, consider to use Autodesk verified graphic cards. what is TS? Quote
CAnnondale Posted June 17, 2016 Posted June 17, 2016 Just used some humor and I was reading it with my phone so couldn’t get into detailsAnyway…. 1.make sure to reset system variables, All Programs > Autodesk > Autocad > Reset Autocad. 2. service packs are a little software Autodesk release after a new version launch in order to fix bugs. 3.make sure no AEC objects and proxies are existing in your drawing. Etransmit the drawing, and in the profile make sure to choose to convert to autocad with AEC exploded. 4.if you invest in a powerful pc, consider to use Autodesk verified graphic cards. what is TS? It is not Humor, it is sarcasm. TS - Thread Starter sent by Wehlee Quote
RobDraw Posted June 17, 2016 Posted June 17, 2016 It is not Humor, it is sarcasm. Umm, sarcasm is a form of humor. Unfortunately, sarcasm does not come across very well in this format. Quote
RobDraw Posted June 17, 2016 Posted June 17, 2016 My guess is command line settings as Dadgad said. Quote
