davidoff Posted June 13, 2016 Share Posted June 13, 2016 I despeerately need some assistance to model a hull of a sailboat. If a guru here could help me I would appreeciat it. Ahmad Quote Link to comment Share on other sites More sharing options...
ReMark Posted June 13, 2016 Share Posted June 13, 2016 You posted your thread in the Solidworks forum yet your profile indicates you are using AutoCAD 2000i. What program are you actually going to use? Quote Link to comment Share on other sites More sharing options...
davidoff Posted June 13, 2016 Author Share Posted June 13, 2016 I thought the question was which programm I use the most. I am just starting with solidworks. versoin 10. I will make the sailboat with solidworks Ahmad Quote Link to comment Share on other sites More sharing options...
ReMark Posted June 13, 2016 Share Posted June 13, 2016 You might want to change your profile then as to avoid any confusion. Thank you. You might also wish to try an Internet search using the following criteria... "solidworks"+"model boat hull" Quote Link to comment Share on other sites More sharing options...
chubarka Posted June 13, 2016 Share Posted June 13, 2016 I will never be mistaken for a Guru, however I do think I can help you. I don't have a sailboat tutorial but I do have a tutorial on the hull design of a canoe, by Ben Eadie. The only difference between the two is the shape of your Table of Offsets will be the shape you sketch, (sailboat hull shape) versus that of a canoe. The basic principle of modeling the hull does not change. Only problem is that my tutorial is over 100MB in size and therefore too large for email. Send me your email address at lotec@cox.net and I will send you a password , user name, and IP numbers so that you can log into my Cloud and download your tutorial. My Cloud is very fast. You will need an FTP program and if you don't have one you can download one for free at http://www.ftpcommander.com. Very easy to use. Hope this helps, Chubarka Quote Link to comment Share on other sites More sharing options...
shift1313 Posted June 13, 2016 Share Posted June 13, 2016 Thats very generous Chubarka! I would like to know a bit more. You really haven't said much. Why do you desperately need a sailboat hull? Im sure you csn download some on http://www.grabcad.com. Are you designing a new one? Are you tasked this by your school or work? One of my clients is in the Yacht industry and they use specific design software to determine the shape of the hull bssed on some input parameters. Designing a boat properly is no minor task. You are talking hundreds to thousands of hours depending on what size and type you are looking for. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted June 14, 2016 Share Posted June 14, 2016 2nd this opinion One of my clients is in the Yacht industry and they use specific design software to determine the shape of the hull Look at America's Cup when the wing keel was introduced you can bet they spent into the Million's inn the design. Quote Link to comment Share on other sites More sharing options...
ILoveMadoka Posted June 17, 2016 Share Posted June 17, 2016 I was going to write out the steps (lofting across a series of planes) but youtube has the answer https://www.youtube.com/results?search_query=SOLIDWORKS+model+boat+hull Quote Link to comment Share on other sites More sharing options...
