welldriller Posted June 14, 2016 Posted June 14, 2016 Yes you can use lisp on AutoCad LT Have i got you attention REMARK Have i tried it -> NO Am i going to try it -> NO I know how to use a keyboard and mouse will stick to that. What i want to know though is has anyone tried this program, if so does it work. You can check it our at http://www.cadsta.com Quote
ReMark Posted June 14, 2016 Posted June 14, 2016 No, you can't use lisp in AutoCAD LT unless you use an add-on program. The last company that tried the same approach was basically brought to its knees by AutoDesk. It took some time but in the end the giant prevailed. I would not be surprised if the same thing happened to Cadsta Pty Ltd. the makers of Cadsta. Quote
BIGAL Posted June 15, 2016 Posted June 15, 2016 2nd Remark comment it used to exist, so if you want lisp buy a clone, cheaper than LT. Same thing with hardware locks, a company started to make them, 1st Autodesk won, higher court company won, 3rd go higher higher court Autodesk won, all about establishing software licensing laws. Quote
welldriller Posted June 22, 2016 Author Posted June 22, 2016 Ok i did not know about the above information. Thank's to both of you for the information. Thought it was something now. Now i know. Quote
f700es Posted June 22, 2016 Posted June 22, 2016 These look like the exact same tools the other company (DRCAuto) had and I think that they bought out the other guy's work after he died. They were in Australia as well. Quote
searching Fox Posted July 20, 2016 Posted July 20, 2016 Good to know - thanks. No, you can't use lisp in AutoCAD LT unless you use an add-on program. The last company that tried the same approach was basically brought to its knees by AutoDesk. It took some time but in the end the giant prevailed. I would not be surprised if the same thing happened to Cadsta Pty Ltd. the makers of Cadsta. Quote
