I'm looking a lisp that can run from modelspace that will move object(s) from modelspace to paperspace. I'm assuming that there is only one paperspace window.
Anyone see anything like this?
Thanks.
Simple and quickie one:
(defun c:test  (/ ss i lst lay doc)
 ;;	Tharwat 15.June.2016	;;
 (if (not (eq (getvar 'ctab) "Model"))
   (princ "\n ** Command not allowed in Paper Space **")
   (if (setq ss (ssget "_:L"))
         (setq lst (cons (vlax-ename->vla-object
                           (ssname ss (setq i (1- i))))
                         lst))
       (setq doc (vla-get-activedocument (vlax-get-acad-object))
             lay (vla-item (vla-get-layouts doc) (car (layoutlist)))
       (vlax-invoke doc 'copyobjects lst (vla-get-block lay))
       (mapcar 'vla-delete lst)
 )(vl-load-com)
Awesome and almost!
The object just needs to be scaled according to the paperspace scale which I can figure out.
Don't know how you guys keep all that knowledge in your head all the time.:D
Hmm, a bit trickier for me than I thought. It needs to scale from 0,0 at the paperspace scale. So I don't know how to access that scale while in modelspace...
Become a habit. :D
What is the scale factor that you would like to scale the objects when they moved to paper space?
Dangit. I just remembered that I can use the dimscale...below didn't work for me.
(defun c:test  (/ ss i lst lay doc int)
                         lst))
       (setq int (1 / (getvar "dimscale")))
       (command "scale" (entlast) "0,0" int)
 )(vl-load-com)
Thanks for chiming in Lee. I saw your LISP but I needed it to be able to run it without having to work through a viewport.
Thanks.
Try this:
(defun c:test  (/ ss i lst lay doc objs int)
   (if (and (setq ss (ssget "_:L"))
                (setq lst (cons (vlax-ename->vla-object (ssname ss (setq i (1- i)))) lst))
              lst
            (apply 'and (setq objs (vlax-invoke doc 'copyobjects lst (vla-get-block lay))))
            (setq int (/ 1. (getvar "dimscale")))
       (mapcar '(lambda (u) (vla-scaleentity u (vlax-3d-point '(0. 0. 0.)) int)) objs)
 )(vl-load-com)
Ah yes, thank you much.
Now I can force those revclouds out of my modelspace...
For my ignorance, is it not possible to use entlast because of VLA?
@ Tharwat:
why do you have this in your code?:
(apply 'and (setq objs ... ))
@ Tharwat:
Because list of objects would always return T even if the elements of the list is a list of nil and in my previous codes I added the apply with and to get sure that all elements in the list is valid and equal to true then to continue to next line.
eg:
_$ (and '(nil nil nil))
T
_$ (and '(t nil nil))
T
_$ (apply 'and '(t nil nil))
nil
_$ (apply 'and '(t t t))
T
@ Tharwat:
I understand that. But I can't think of a case where (vlax-invoke doc 'copyobjects ...) returns a list with a nil.
Agreed and it is just another way of writing the program, nothing's more.
