Hi guys,
I just wrote this "imitation" of ACAD's selection, using CPolygon method:
; Grrr
; Grips a selection, if the user specifies the polygon shape, and there are objects in the enclosed area or crossing it
(defun C:test ( / ptlst pt ptx ptf SSCP cnt lwp h )
(setq go T)
(while go
	(initget 128 "Done") ; allows all inputs
	(cond
		((and (not pt) (not (or (= pt "Done")(= pt "D"))) )
			(setq pt (getpoint "\nPick first point "))
			(setq ptlst (list))
			(setq ptlst (cons pt ptlst))
			(setq ptx pt)
			(setq ptf pt)
		((and (setq pt (getpoint "\nPick Next point or [Done], yellow line can be modified" ptx)) (= (type pt) 'LIST) )
			(if (and (= (type pt) 'LIST) (= (type ptx) 'LIST))
					(if (and (= 'ename (type lwp)) (entget lwp)) (entdel lwp))
					(if (and (= 'ename (type h)) (entget h)) (entdel h))
					(redraw)
					(grdraw (car ptlst) (last ptlst) 2 2)
					(if (> (length ptlst) 2)
							(setq cnt 0)
							(repeat (- (length ptlst) 1)
								(grdraw (nth cnt ptlst) (nth (setq cnt (+ cnt 1)) ptlst) 1 2)
							(LWPoly ptlst 1)
							(setq lwp (entlast))
							(vl-cmdf "_.HATCH" "T" 50 "CO" 1 "S" lwp "" "")
							(setq h (entlast))
							(entupd h)
							(vl-cmdf "_.DRAWORDER" h "" "B")
			(setq ptx pt)
		((and (or (= pt "Done")(= pt "D") (null pt)) (>= (length ptlst) 2))
			(setq go nil)
			(redraw)
			(if (setq SSCP (ssget "_CP" ptlst ))
					(sssetfirst nil SSCP)
					(setq go T)
); while
(defun LWPoly (lst cls)
(entmakex
	(append
		(list
			(cons 0 "LWPOLYLINE")
			(cons 100 "AcDbEntity")
			(cons 100 "AcDbPolyline")
			(cons 90 (length lst))
			(cons 70 cls)
		(mapcar (function (lambda (p) (cons 10 p))) lst)
I have no questions or anything, its just a practice work and I've decided to share it.
