Modify a selected block, keep other blocks with the same name intact
Hi forum
Is it possible to modify a selected block, keeping other blocks with the same name intact. For more details please refer to the image attached.q1.jpg
Thanks
Make the block dynamic and add the two shapes to the block on the two sides and that would be much better than a adding two separate blocks on the two sides.
Tharwat
My block looses its dynamical properties when i scale it, and i scale it for following reasons
samifox
The referred function requires Standard INSERT ename. I don't know what it is exactly but wherever i use my block name "blk" or # for the argument i get this message
*** Not A Changeable Block ***
Thank you for trying to solve my problem ,but there is a distortion of a hatch
I am giving you an example of how to create the Dynamic Block with parameters so you can adjust and modify the Hatch resolution and looking as best as you want.
Where do i play with hatch resolution, a quich search did't give me answer
Double click on the Block to open the Block Editor and adjust it to your needs.
Do me a favor. Try to prolong the pipe until you get a distortion then tell me the steps how to adjust the resolution after accessing block editor and clicking on hatch please.
Even if it works this takes less clicks
(defun c:NP (/ pt1 pt2)
 (defun open_dbx (dwg / dbx)
   (if	(< (atoi (substr (getvar "ACADVER") 1 2)) 16)
     (setq dbx (vlax-create-object "ObjectDBX.AxDbDocument"))
	  (strcat "ObjectDBX.AxDbDocument."
   (vla-open dbx dwg)
   dbx
 (setq Dbx (open_dbx "c:/Users/the good custumer/Desktop/PrepAutocad/Pipes.dwg"))	; Change the file name here
 (vla-CopyObjects
   Dbx
   (vlax-safearray-fill
     (vlax-make-safearray vlax-vbObject '(0 . 0))
     (list (vla-item (vla-get-blocks dbx) "NP"))
				; Change the block name here
   (vla-get-blocks
     (vla-get-activedocument (vlax-get-acad-object))
 (vlax-release-object dbx)
 (if (and (setq pt1 (getpoint "\nPick Insertion point."))
   (not (initget 32))
   (setq pt2 (getpoint pt1 "\nPick Insertion point."))
   (setq ang1 (angle pt1 pt2))
   (setq ang2 (/ (* ang1 180.0) pi))
   (command "._-insert"
     "NP"
     "_non"
     pt1
     (distance pt1 pt2)
     "1"
     ang2
