Привет форум,
1.Is it possible for a user to select multiple layers from a list of existing layers without playing with DCL? If yes,how?
2.Is it true, that getkword function allows to select only one item?
I want the user to pick layers from a list and record picked layers
("Layer3" "Layer2" "Layer1" "0")
Спасибо
Edited by NoroZorro
Here's a simple example:
(defun getlayers ( / def itm lay lst sel )
   (while (setq def (tblnext "layer" (not def)))
       (setq lst (cons (cdr (assoc 2 def)) lst))
   (while (/= "" (setq lay (getstring t "\nEnter layer name <done>: ")))
       (cond
           (   (not (setq itm (car (member (strcase lay) (mapcar 'strcase lst)))))
               (princ (strcat "\nLayer " lay " not found."))
           (   (member itm sel)
               (princ (strcat "\nLayer " itm " already selected."))
           (   (setq sel (cons itm sel))
               (princ (strcat "\nSelected layers: " (last sel)))
               (foreach lay (cdr (reverse sel)) (princ ", ") (princ lay))
Thank you, i will put this code on my analyze code list
To answer your question #2. (getkword) allows a user to select from a list of options established by a preceding call to the (initget) function. See the basic example of (getkword) below:
;; Initialize the options.
;; NOTE: Capitalized letter can be typed in by itself
;;       i.e. "O" will return "One", "T" will return "Two", etc...
;; Optionally (initget) can be called with a bitcode of 1 to force the user to type an
;; option, rather than just <ENTER>. There are additional bitcodes as well, but
;; only bitcode 1 can apply to (getkword)
;; CORRECTION (getkword) can also accept bitcode 128 to allow other arbitrary input strings, but I would not recommend it.
;; Example: (initget 1 "One Two tHree Four")
;;          (setq opt (getkword "\nYou must enter one of the following options [One/Two/tHree/Four]: "))
(initget "One Two tHree Four")
(setq opt (getkword "\nSelect an Option [One/Two/tHree/Four] <One>: "))
(if (= opt nil)(setq opt "One")) ;; set the default if the user just pressed <ENTER>
;; Note (getkword) will always return the complete keyword,
;; regardless if the user used the shortcut mnemonic or the whole keyowrd.
(cond
  ((= opt "One")
    ;; do code for Option 1
  ((= opt "Two")
     ;; do code for Option 2
  ((= opt "tHree")
     ;; do code for Option 3
  ((= opt "Four")
     ;; do code for Option 4
