hi
i want to set all Xref VP color to x. i use
vplayer color current *
and all VP set to x.
but i want the scope of the command to be the XREF layers only.
is it possible?
TX
use the pipe symbol *|* to select all layers that use that symbol
was it made to address this requiement?
The pipe symbol is used in the name of all xref layers, autocad adds it automatically, so using the wildcard symbol * will select all layers, whereas using *|* will select all the xref layers (unless you happen to use that symbol in your layer names)
In the Layer Manager, use Wildcard matching in a Property Filter along with the pipe symbol "|" to show only XREFs. Here's the code:
So, going off the Wildcards, the tilde matches anything but the pattern. The asterisks grabs everything with the Pipe Symbol "|" which only XREF layers can have. This will isolate only XREF layers, allowing you to Shift+Select and change layer properties quickly.
Wildcard reference:
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2015/ENU/AutoCAD-Core/files/GUID-5818FE81-B822-45AC-BAB0-3517376EA402-htm.html
Wildcard reference:
TX
never notice that. nothing exist without a reason hu?
for all other fellows, macro works greate
^C^Cvplayer color 8 *|* Current;;
TX
I actually gave you the wrong info... that was my code to NOT show Xrefs in my Layer Manager. Which, AutoCAD now does automatically. This was implemented in my template well before this was a standard function. Either way, seems like you got it figured out.
TX
Nice to see you got it working
