Hi,
I would like sort coords of circles through x and y coordinate (from left to right and from up to down), but,
I whant to add "precision"
Lets consider following source list:
'((0.8 1.6) (2.4 1.4) (1.2 1.3) (1.8 1. (3.0 0. (2.8 2.3))
With precision 0.5 sorted list should look like:
'((0.8 1.6) (1.8 1. [b](2.8 2.3)[/b] (1.2 1.3) (2.4 1.4) (3.0 0.)
With precision 0.2 sorted list should look like:
'([b](2.8 2.3)[/b] (0.8 1.6) (1.8 1. (1.2 1.3) (2.4 1.4) (3.0 0.)
To see what for I needthis, please check this thread
-------------------------EDIT
This is my sorting function, but i don't know how to add precision...
(vl-sort ptlist
 '(lambda (x y)
   (cond
     ((= (cadr x)(cadr y))(< (car x)(car y)))
     ((> (cadr x)(cadr y)))
Edited by ziele_o2k
I found solution here
;;; Sort a list of 3d elements
;;; From: "Tony Tanzillo" <tony.tanzillo at caddzone dot com>
;;; Newsgroups: autodesk.autocad.customization
;;; Subject: Re: How can I sort a list of 3d points?
;;; Date: Wed, 19 Mar 2003 10:37:20 -0500
;;; You can use vl-sort, with a comparison function that
;;; weights the ordinates in whatever way you want.
;;; Here's an example that gives the greatest weight
;;; to the X ordinate, and the least weight to the Z
;;; ordinate:
;;; sort on three keys (x, y, and z)
 (defun-q compare-points (a b / fuzz)
    (setq fuzz 1.0e-6) ;; comparison precision
    (if (equal (car a) (car b) fuzz)
       (if (equal (cadr a) (cadr b) fuzz)
          (> (caddr a) (caddr b))
          (> (cadr a) (cadr b))
       (> (car a) (car b))
;;; example  (vl-sort <list-of-points> 'compare-points)
;;; If you search this newsgroup, you'll find a much
;;; more powerful sorting function along with a good
;;; discussion on why (vl-sort) can be very dangerous.
;;; For that reason, I suggest you replace the built-in
;;; vl-sort with this:
(defun-q vl-sort (lst func)
  (mapcar
    '(lambda (x) (nth x lst))
     (vl-sort-i lst func)
;;; This will ensure that (vl-sort) does not remove
;;; elements that it sees as equal.
;;; LSORT.LSP  Copyright 1992-98  Tony Tanzillo  all rights reserved
;;; Merging complex list sort
;;; LSORT.LSP implements a modified version of the classic
;;; merge sort algorithm that sorts arbitrarily-complex lists
;;; using a caller-defined relational predicate function.
;;;  (lsort <list> <OnCompare>)
;;;  <OnCompare> is a function that takes two arguments,
;;;  and returns non-nil if the first argument is greater
;;;  than the second, or nil otherwise. The arguments are
;;;  the elements of the list to be sorted. This argument
;;;  must be quoted.
;;;  The default sort order is descending. To change the
;;;  sort order to ascending, the <OnCompare> function can
;;;  return the logical complement (not) of it's result.
;;; Examples:
;;;  1.  Sort a list of coordinates on the Y-component:
;;;      Assume unsorted data is in 'UNSORTED
;;;    (setq sorted
;;;       (lsort unsorted
;;;         '(lambda (a b)
;;;             (> (cadr a) (cadr b))
;;;  2.  Sort a list of entity names by layer:
;;;    (setq sorted
;;;       (lsort unsorted
;;;         '(lambda (e1 e2)
;;;            (> (cdr (assoc 8 (entget e1)))
;;;               (cdr (assoc 8 (entget e2)))
;;;  3.  Sort a list of coordinates on multiple
;;;      keys (first by the X ordinate, and then
;;;      by the Y ordinate):
;;;     (setq epsilon 1e-6)
;;;     (defun-q compare-points (p1 p2)
;;;        (cond
;;;           (  (equal (car p1) (car p2) epsilon)  ; if x are equal,
;;;              (> (cadr p1) (cadr p2)))           ; then compare y,
;;;           (t (> (car p1) (car p2)))             ; else compare x
;;;     (setq sorted (lsort unsorted 'compare-points))
(defun-q lsort (input OnCompare / fun)
  (setq fun (cond (OnCompare) (t '>)))
  (lsort-aux input)
(defun-q lsort-aux (input)
  (if (cdr input)
     (  (lambda (tlist)
           (lsort-merge
              (lsort-aux (car tlist))
              (lsort-aux (cadr tlist))
        (lsort-split input)
     input
(defun-q lsort-split (right / left)
  (repeat (/ (length right) 2)
     (setq
        left (cons (car right) left)
        right (cdr right)
  (list left right)
(defun-q lsort-merge (left right / out)
  (while (and left right)
     (if (apply fun (list (car left) (car right)))
        (setq
           out (cons (car left) out)
           left (cdr left)
        (setq
           out (cons (car right) out)
           right (cdr right)
  (append (reverse out) left right)
Now I have to understand coding :)
