rhbelter Posted June 20, 2016 Posted June 20, 2016 Ahoy, CadTutor, I am a new member to this site. Not new to AutoCad, but not very accomplished. Some fairly simple files have ballooned to 'large'. Autocad 16 Example: One crept-up from ~~ 3 megs to 12 megs. Saved -w- new name, erased all, purged, and with addition of a single 200" line, is way down to 11.9 megs!!!!!!!?????? That must be a pretty aggressive line. Any fix? I'd hate to re-draw all, particularly if it may happen again. Thanks /s/ Bob Quote
BIGAL Posted June 21, 2016 Posted June 21, 2016 Check your blocks for $acd12mhjj etc these are copied and pasted blocks often a block can be a whole dwg hidden away somewhere find it explode delete and purge. At worst wblock out your model space, copy paste/add your paperspace objects one at a time and find the offending object. What does zoom e do a little dot in each corner ? Offending object will be at 1 of the corners. Unfortunately as its 12mb you could if happy copy to a drop box and someone may have a look. Quote
ReMark Posted June 21, 2016 Posted June 21, 2016 My guess is you have an over abundance of linetypes in your drawing that may have been associated with Microstation. Take a look. Do any of the linetype types include the letters DGN? Quote
lamensterms Posted June 26, 2016 Posted June 26, 2016 Sometimes multiple PURGEs are required. Try PURGE > AUDIT > PURGE, save, close and re-open drawing and repeat. Are you running any ACAD addon software that might be adding data/dictionaries to your drawings? Also have a look here for some usual suspects... https://carefuldrafter.wordpress.com/2014/07/22/reduce-file-size-in-autocad/ Quote
ReMark Posted June 26, 2016 Posted June 26, 2016 The process I recommend is this... Overkill -Purge, Regapps -Purge, All Audit Run the above sequence twice saving after the first run through. If that doesn't do the trick try using the WBLOCK command. Quote
