ktbjx Posted June 27, 2016 Posted June 27, 2016 can someone help me make a lisp loop routine to make LINE and copy the Position Y, and paste it as Position Z??? so Position Y and Position Z will be the same?? please???? this would help us a lot! SO: Start Y = Start Z End Y = End Z Sample.dwg Quote
Tharwat Posted June 27, 2016 Posted June 27, 2016 Hi, What is the purpose of uploading a drawing with a few lines without showing the final result you are after? Quote
ktbjx Posted June 27, 2016 Author Posted June 27, 2016 Hi, What is the purpose of uploading a drawing with a few lines without showing the final result you are after? i did, you see, Start y and Start Z are the same. and also End y and End Z are the same, something like that is what we needed, pretty please?? Quote
Tharwat Posted June 27, 2016 Posted June 27, 2016 Upload another drawing showing an example of the final result you looking forward if that is possible. Quote
ktbjx Posted June 27, 2016 Author Posted June 27, 2016 Upload another drawing showing an example of the final result you looking forward if that is possible. Here: all i really need is copy the Start Y, End Y and paste in to be Start Z End Z as you will see in the DWG, Start Y = Start Z and End Y = End Z example: Start X: 1935.5987 Start Y: 1234.9632 Start Z: 1234.9632 End X: 1935.5676 End Y: 1237.3441 End Z: 1237.3441 Every single line created is like that... so you can see its very time consuming and we are rushing things. i was wondering if i can do it in list routine that every line we make, the Y and Z are the same. in the case our productivity will be faster thank you and im sorry for asking too much Sample2.dwg Quote
Stefan BMR Posted June 27, 2016 Posted June 27, 2016 Very simple. Do you want to learn how to do it? Quote
ktbjx Posted June 27, 2016 Author Posted June 27, 2016 Very simple. Do you want to learn how to do it? YES! very much SIR! Quote
Stefan BMR Posted June 27, 2016 Posted June 27, 2016 Ok. First, let's make a SelectionSet. Can you write it for me? Quote
ktbjx Posted June 27, 2016 Author Posted June 27, 2016 Ok. First, let's make a SelectionSet. Can you write it for me? And? Command??? Quote
Stefan BMR Posted June 27, 2016 Posted June 27, 2016 nope. (setq ss (ssget "_:L" '((0 . "LINE")))) This will make a selection of editable (not on locked layer) lines. Do you have the lines in your drawing, isn't it? Quote
ktbjx Posted June 27, 2016 Author Posted June 27, 2016 nope. (setq ss (ssget "_:L" '((0 . "LINE")))) This will make a selection of editable (not on locked layer) lines. Do you have the lines in your drawing, isn't it? okay? im trying to understand, but go on Quote
Stefan BMR Posted June 27, 2016 Posted June 27, 2016 So, do you have the lines on the drawing, or you want to create them by lisp? PS. Please do not edit your post and press F5 to see my posts quicker. Quote
ktbjx Posted June 27, 2016 Author Posted June 27, 2016 So, do you have the lines on the drawing, or you want to create them by lisp? PS. Please do not edit your post and press F5 to see my posts quicker. no, I already have the lines on my drawing sir Quote
Stefan BMR Posted June 27, 2016 Posted June 27, 2016 ok. We have the selection set. We need a counter. This will help us to get each object from selection. (setq i 0) Quote
ktbjx Posted June 27, 2016 Author Posted June 27, 2016 ok.We have the selection set. We need a counter. This will help us to get each object from selection. (setq i 0) ok, but why is it set to 0 sir??? sorry for asking Quote
Stefan BMR Posted June 27, 2016 Posted June 27, 2016 No problem. It is because the selection set is based on 0 index. The first element has the index 0, not 1. Quote
Stefan BMR Posted June 27, 2016 Posted June 27, 2016 Now we start the iteration using repeat function. But first, we need to know when to stop, so we need to know the number of the objects in selection set. Can you write the code for these tasks? Quote
ktbjx Posted June 27, 2016 Author Posted June 27, 2016 No problem. It is because the selection set is based on 0 index. The first element has the index 0, not 1. owh okay i get it now. go on Quote
Stefan BMR Posted June 27, 2016 Posted June 27, 2016 Did you read the post #17? Can you or not? Quote
ktbjx Posted June 27, 2016 Author Posted June 27, 2016 Now we start the iteration using repeat function. But first, we need to know when to stop, so we need to know the number of the objects in selection set. Can you write the code for these tasks? (while im sorry if its wrong Quote
