RobDraw Posted July 6, 2016 Posted July 6, 2016 What was the solution? I don't see how he did anything special. You must have contacted him via PM like you did me. The purpose of these forums is to post solutions, so as to help others. Please post your solution. Quote
Casusa Posted July 6, 2016 Author Posted July 6, 2016 Probably bad insertion data. Halam told me: "For inserting... Command : Xref Insert multiple, use shift to select Point type 0,0 Done. Afterwards command xref again Select all the xrefs Bind, then choose insert as option. Now they are all inserted as blocks." It was by PM, it contains sensitive data. Thank you all. Quote
RobDraw Posted July 6, 2016 Posted July 6, 2016 I thought you were doing something similar from the start. Quote
halam Posted July 6, 2016 Posted July 6, 2016 Glad I could make it work , not very complicated. I showed him how easy irt.vlx works to check world coordinates (Portuguese) and insert some satellite image underlay. As Civil engineers.. Quote
