Hi,
I'm relatively new to autocad and using the 2010 version...
My problem is WHILE using the multiline command, I can't snap back to points created in that line?
I can snap to ordinary lines and other multilines that have been created PREVIOUSLY...but not back to a multiline that I'm CURRENTLY drawing??
Why is this?
Thanks for any help...
Welcome to CADTutor RBT. :)
Are you DISPLAYING JOINTS in your multiline style?
In the screenshot you will see the Standard multiline style on top, the one below is a new style I defined from the Standard one, and the only difference is that on the newer one, I checked DISPLAY JOINTS in the dialog box. There are a bunch of options available at this point in defining a new multiline style.
If you use the MLEDIT command, there are a number of helpful tools you can use, as shown in the dialog box in the screenshot.
And last but by no means least, Lee Mac has a great lisp for those who enjoy the advantages of multilines, but want the other advantages of Plines.
http://www.lee-mac.com/mlinetopline.html
Thanks Lee! :beer:
Thanks for the reply Dadgad!
I tried the DISPLAYING JOINTS, and it still doesn't let me snap back to it.
The MLEDIT is a great tool, thanks for that, never knew about that!
I think the link you posted is what i'm after... so I'll check that out!
Basically, from what I'm finding, if I was to try to draw a rectangle or square using a multiline, I can't finish the rectangle because I can't snap back to the beginning...
How is your multiline Justification set, to Zero?
That LSP by Lee Mac is awesome, as nice as multilines are to draw quickly, they carry a lot of baggage for editing down the road, unlike Lee's wonderful closed polylines! :beer:
Oh, now I see what you mean!
Just use C for close, and the final segment will close the multiline, as it would with a polyline, much easier than snapping to a nonexistent grip. :wink:
WHEN ALL ELSE FAILS, read your commandline prompts, there is much to be learned by doing so. :|
Edited by Dadgad
