Hello, Im new to lisp and im trying to create a lisp program that goes through my typical layout tabs and sets up the layers to be frozen or thawed.
I would like to switch to each layout tab and set things up automatically
1. set to model space
2. thaw the layers needed
Leaving layer 1 on at all times for the border.
and skip error's if a layout tab is missing.
(setvar "ctab" "front elevation")(command "_.mspace")(command "vplayer" "f" "~1" "")(command "vplayer" "thaw" "e" "")
(princ))
(setvar "ctab" "rear elevation")(command "_.mspace")(command "vlayer" "f" "~1" "")(command "layer" "thaw" "er" "")
(princ))
(setvar "ctab" "right elevation")(command "_.mspace")(command "vlayer" "f" "~1" "")(command "-layer" "thaw" "es" "")
(princ))(ignore-errors)
Can anyone here help me to get started? Thanks
the next question would be, how do I thaw multiple layers?
(defun c:Test nil
(if (member "FRONT ELEVATION" (layoutlist)) ; it's case sensitive
(setvar "ctab" "FRONT ELEVATION")
(if (= (getvar "cvport") 1) (command "_.mspace"))
(command "_.vplayer"
"f" "~1" ""
"thaw" "e" "" "")
(if (member (strcase "REAR ELEVATION") (mapcar 'strcase (layoutlist))) ; not case sensitive
(setvar "ctab" "REAR ELEVATION")
"f" "~1" ""
"thaw" "er" "" "")
(if (member "RIGHT ELEVATION" (layoutlist))
(setvar "ctab" "RIGHT ELEVATION")
"f" "~1" ""
"thaw" "es" "" "")
(if (member "1ST FLOOR PLAN" (layoutlist))
(setvar "ctab" "1ST FLOOR PLAN")
"f" "~1" ""
"thaw" "0" "" ""
"thaw" "2" "" "" )
(setvar "ctab" "COVER")
Thaw multiple thaw a* use wildcard option * any layer starting with a
Also thaw "0,2,a*" is a valid option for 3+ layers
http://www.lee-mac.com/steal.html
I would just set it up once (just like a template system) and then use Lee Mac's excellent Steal program. It is how I have my office setup.
That is what I'm doing,, setting up a template system.
I have more luck with bland.lsp, vs steal
"f" "~1" ""
"thaw" "er" "" "")
(command "-vports" "Lo" "on" "ALL" "")
(command "zoom" "e")
Would it be possible to have the left hand corner of the layout tab view at 0,0
And scale the drawing to 3/16" = 1" before I lock and zoom extents?
I'm still trying to get the lower left corner of the view port to stay at 0,0 when I zoom to scale.
(if (member "COVER" (layoutlist)) ; it's case sensitive
"f" "~1" ""
"thaw" "COVER" "" "")
(command "-vports" "Lo" "off" "ALL" "")
(command "zoom" (strcat "1/48" "" "XP")) ; = 1/4" scale viewport
