Hi, I'm trying to create a routine to draw trapezoidal threads in Adcad2000. I don't understand why it does not work.
Can someone help me? I really appreciate, hugs.
Code:
;Program that subtracts a 'cut entity' of a cylinder, shifts it along
;and turns it to make new cut, "N" times each "M" turns.
;Requirements: horizontal cylinder axle and load of "geom3d.arx" (Acad2000).
(DEFUN C:LATHE (/) (Setq AUN (getvar "aunits")) (setvar "aunits" 0)
(setq Cylinder (entsel "\nClik the Cylinder to 'lathe': "))
(setq PtoA (GETPOINT "\nClick at START (center) of Cylinder: "))
(setq PtoB (GETPOINT "\nClick at END of Cylinder (center): "))
(setq CutEntity (entsel "\nSelect a 'CUT-ENTITY': "))
(princ "\nTotal Number of TURNS (spiral): ") (setq NTv (getint)) (setq Nv 1)
(princ "\nHow many CUTS by TURN (resolution): ") (setq NCv (getint))
(setq Nc 1) (setq Step (/ (distance PtoA PtoB) (* NCv NTv)))
(setq AngularStep (/ 360 NCv)) (setq PtoC (polar PtoA (angle PtoA PtoB) Step))
(while (>= NTv Nv)
(while (>= NCv Nc)
(command "copy" CutEntity "" "0,0,0" "0,0,0")
(command "subtract" Cylinder "" CutEntity "")
(command "move" Cylinder PtoC PtoA)
(command "rotate3d" Cylinder PtoA PtoB AngularStep)
(setq Nc (+ Nc 1))
(setq Nv (+ Nv 1)) (setq Nc 1)
) (setvar "aunits" AUN)
Edited by Cunha
Link to post
Lee Mac
After a cursory glance over your code, try setting OSMODE to 0 before your while loop, resetting it afterwards (as you have with AUNITS).
Link to post
Thanks Lee. I have made the alteration and some changes; beyond the control of Osmode, now I'm referencing the cylinder just by entity name (because it remains even after move, rotate and cut) and I kept control of repetitions without using counters (an old mania).
Now it's stopping for exceeding 4 level of nesting and crashing run. Can't understand.
; --- July/14/2016 --- Attention please: This program IS NOT FUNCTIONAL yet.
(DEFUN C:LATHE (/)
(Setq OSM (getvar "osmode")) (setvar "osmode" 0)
   (setq Cyl (entsel "\nClik the Cylinder to 'lathe': "))
   (setq Cylinder (car Cyl))
   (repeat NTv
     (repeat NCv
 ) (setvar "aunits" AUN) (setvar "osmode" OSM)
Edited by Cunha
Link to post
