Hi
Trying to draw a three brick 'voussoir' for the surround to a window arch in an Axonometric/Isometric drawing?
Using the Path Array function but spacing seems to go all wrong. The angles are correct but the spacing is all wrong
Hope that link works, many thanks in advance
You won't get that to work for an isometric drawing, much better off to draw it in an ortho view and then switch the View Controls for a SW or SE iso.
Or create a 3D model of the arch and extract the isometric view from the model.
