muck Posted January 7, 2009 Posted January 7, 2009 AutoCAD 2009 VBA I have been using the following code to pick a dimension variable in Objdimsension. Then I set my specific autoCAD variable. Is it possable to modify this code to pick my dimension then create & save a dimstyle using all the variables in objdimension object. Maybe I could loop thru objdimension then set variables in my dimstyle object. Does anyone have a sample of this? Code: Private Sub CommandButton2_Click() Dim objDimension As AcadDimension Dim varPickedPoint As Variant Dim objDimStyle As AcadDimStyle Dim strDimStyles As String Dim strChosenDimStyle As String Dim stg As String On Error Resume Next Me.hide ThisDrawing.Utility.GetEntity objDimension, varPickedPoint, _ "Picked a dimension whose style you wish to set" If objDimension Is Nothing Then MsgBox "You failed to pick a dimension object" Exit Sub End If stg = "Textheight" 'MsgBox objDimension.TextRotation 'ThisDrawing.SetVariable "CLAYER", objDimension.DimensionLinelayer MsgBox objDimension.ExtensionLineExtend ThisDrawing.SetVariable "dimexe", objDimension.ExtensionLineExtend MsgBox objDimension.ExtensionLineOffset ThisDrawing.SetVariable "dimexo", objDimension.ExtensionLineOffset MsgBox objDimension.Layer ThisDrawing.SetVariable "CLAYER", objDimension.DimensionLinelayer MsgBox objDimension.DimensionLineColor ThisDrawing.SetVariable "DIMCLRD", objDimension.DimensionLineColor MsgBox objDimension.ExtensionLineColor ThisDrawing.SetVariable "DIMCLRE", objDimension.ExtensionLineColor MsgBox objDimension.color 'Dim text color ThisDrawing.SetVariable "DIMCLRT", objDimension.color MsgBox objDimension.ScaleFactor ThisDrawing.SetVariable "Dimscale", objDimension.ScaleFactor ThisDrawing.SendCommand "Dimscale" & vbCr ThisDrawing.SendCommand objDimension.ScaleFactor & vbCr MsgBox objDimension.VerticalTextPosition ThisDrawing.SetVariable "DIMTAD", objDimension.VerticalTextPosition MsgBox objDimension.TextHeight ThisDrawing.SetVariable "DIMTXT", objDimension.TextHeight '****Text Style MsgBox objDimension.TextStyle 'ThisDrawing.SetVariable "DIMTXT", objDimension.TextHeight ThisDrawing.DimStyles.StyleName , objDimension.TextStyle MsgBox objDimension.TextGap ThisDrawing.SetVariable "DIMJUST", objDimension.TextGap MsgBox objDimension.ArrowheadSize ThisDrawing.SetVariable "DIMASZ", objDimension.ArrowheadSize Set objDimStyle = ThisDrawing.DimStyles.Add("YourNamedStyle") objDimStyle.CopyFrom ThisDrawing ThisDrawing.ActiveDimStyle = objDimStyle 'Make your changes here.................... objDimStyle.CopyFrom ThisDrawing '"YourNameStyle" objDimStyle.Name = "YourNamedStyle" End Sub Quote
