rbarrios_cad Posted January 7, 2009 Posted January 7, 2009 The problem is hard to describe. As of yesterday it does not matter what view I try to pull a dimension in (in modelspace) the dimension tries to create in the top view. I cannot pull an elevation, it reads as zero and can only be seen in the top view. It started happening yesterday after I attempted to produce a FLATSHOT. I don't know if maybe the UCS got screwed up, it must have been some minor setting I hit. Is anyone familiar with this problem? The problem is set no matter if I work on this new drawing or an old one (that never had the problem before). Quote
rkent Posted January 7, 2009 Posted January 7, 2009 The problem is hard to describe. As of yesterday it does not matter what view I try to pull a dimension in (in modelspace) the dimension tries to create in the top view. I cannot pull an elevation, it reads as zero and can only be seen in the top view. It started happening yesterday after I attempted to produce a FLATSHOT. I don't know if maybe the UCS got screwed up, it must have been some minor setting I hit. Is anyone familiar with this problem? The problem is set no matter if I work on this new drawing or an old one (that never had the problem before). UCS set to World. Plan set to World. Quote
