I have a simple block in my drawing file called "JC". I would like to use the array command to copy this block into a single row with 12 columns. I can do it using the command line but can't seem to find a way to select the block using LISP.
Something like below maybe use vl-add-array
(command "INSERT" JC pt 1 1 0) ; pt bottom left etc
(setq obj (entlast))
(command "-array" obj "" "R" 5 5 100 100)
