Problem with bcount & dynamic blocks
I'm looking for a routine like bcount that I can select an area of blocks, and tell you how many of each there are.
I've run into a problem with bcount not counting all the dynamic blocks. When I've activated a flip or a rotate parameter after a block has been inserted, it seems to not get picked up by the bcount routine. It does however show up with quick select, but that is just counting one block name at a time.
Thanks for any suggestions.
Thanks ReMark!
That will pacify the boss. He grumbled that he couldn't window an area, but thought he could work around the issue in those cases.
You're entirely welcomed, yrnomad.
Another satisfied customer. :)
