Hello, I hope all is well.
I am trying to modify a reactor for a user who wants the viewport layer to turn off when a dimension command is active.
The code I inserted works by itself but does not work within the reactor.
Any ideas?
(foreach itm comLst
     (if (member (car args) itm)
  (if (not (tblsearch "LAYER" (caar itm)))
      (setq nLay (vla-Add (vla-get-Layers
			    (vla-get-ActiveDocument
			      (vlax-get-acad-object)
			    ) ;_ end of vla-get-ActiveDocument
			  ) ;_ end of vla-get-Layers
			  (caar itm)
		 ) ;_ end of vla-Add
      ) ;_ end of setq
      (vla-put-Color nLay (cadar itm))
      (setq com:resFlg T)
    ) ; end progn
  ) ; end if
  (setq	com:oldLay
	 (getvar "CLAYER")
	com:resFlg T
  ) ;_ end of setq
  (setvar "CLAYER" (caar itm))
  [color="red"](if (= "DIM" (getvar 'clayer))
    (vl-cmdf "-layer" "off" "XVIEW" "" "")
  )[/color] ;_ end of if
) ; end progn
     ) ; end if
You can't use commands inside reactor callbacks. Use (vla-put-layeron ... :vlax-false).
Ah, that was it.
Thank you. :beer:
For future reference, you can also use vla-sendcommand if you need to use a command specifically in the reactor. The vla-sendcommand sends a command string to autocad.
Thank you for that Broncos, I was unfamiliar with that.
Would you have any reason why the AfraLisp website would report this:
You should never use this method to issue a command for which there is an ActiveX method available. For example, do not use SendCommand "VBALOAD ". Instead, use the LoadDVB method.
I am not 100% sure on the why. One reason that comes to mind though is that vla-sendcommand sends stuff to the command line, which could slow down the LISP routine if is used frequently throughout it. If you want to see an example of a reactor that makes use of it, go to http://www.cadtutor.net/forum/showthread.php?93661-Lisp-for-fillet-radius./page2 for the fillet reactor and offset reactors (they both are very handy and BigAL's finalized one on page 3 is really cool).
Nice, thanks for that broncos.
