AJSmith Posted August 5, 2016 Posted August 5, 2016 One of our caddies has a different issue to one iv ever seen when trying to edit the drawing frame (a attributed block) he cant double click to bring up the editor dialog box ??? also may be related he can select a item and apply a command (select a block and move it) he has to start the command and them the item nothing to big just messes up the way he normally works any ideas ?? many thanks Quote
Dadgad Posted August 5, 2016 Posted August 5, 2016 OPTIONS > User Preferences, Enable double click editing, standard windows behavior, which changes the DBLCLKEDIT system variable, as shown? Quote
Dadgad Posted August 5, 2016 Posted August 5, 2016 Oh wait, sounds like Noun Verb selection, the PICKFIRST system variable? Or can be changed on the Options Selection Tab. It is just a Block, not an Xref, right? Quote
AJSmith Posted August 5, 2016 Author Posted August 5, 2016 PICKFIRST brilliant totally forgot about that thank you Quote
Dadgad Posted August 5, 2016 Posted August 5, 2016 May all your obstacles be so surmountable. Glad I could help you. Probably got changed by escaping out of a poorly written lisp. Might be a good time to go to the SYSVDLG box, and do a SAVE ALL, to create an .svf file, which can later be used to either share, transfer, or restore your favored system variable settings. Name it appropriately and stash it away where you will be able to find it, the next time things get out of whack. If you even need to summon it, to get you out of a jam, use the READ button at the bottom of that dialog, and Browse to it and load it, so your system variables will be restored to how you usually have them. Quote
