Thomas Baxter Posted August 7, 2016 Posted August 7, 2016 How do i recover a drawing lost I model space when I did a zoom all Quote
steven-g Posted August 7, 2016 Posted August 7, 2016 I doubt it is lost, you probably have some items way off in space, just press undo a couple of times to get back to where you were, then you need to figure out what is causing the problem, if you can post the drawing someone might be able to help figure it out. Quote
Dadgad Posted August 8, 2016 Posted August 8, 2016 steven-g, as is his wont, is right on the mark. Before posting the drawing, just go to Model space, Zoom Extents, then hit CTRL + A, which will select everything in the drawing, at which point you will likely see that right at two opposed edges of your screen, you will see two tiny little objects highlighted. One of those will be the digial flotsam, a bit of errant text, or anything else, which makes this happen, and on the opposite edge will be the drawing which you believe has been lost. If you still don't see it, change to Conceptual visual style, as sometimes, the color shift makes things stand out a bit more on the screen. Quote
