Gearbox Posted August 8, 2016 Posted August 8, 2016 Having an issue here and hope someone can help out with. I am running 2013 version of AutoCAD and I want to export a 2D file so another user can open it up in Tekla Structures. We can get the file opened in Tekla with no problem, however when it shows up in tekla, the fonts are different (all the same in the AutoCAD file) the file itself is quite small with not a whole lot of detail. I have tried exporting to earlier version only to have pretty much the same result. the file being exported is not going into the 3D model just into the drawing side of things in Tekla. Thanks!! Quote
