ernestkwarteng Posted August 9, 2016 Posted August 9, 2016 please i would be glad if some one can help with a lisp script that can convert multiple dng file to dxf. REGARDS!!!!! Quote
Dadgad Posted August 9, 2016 Posted August 9, 2016 (edited) Welcome to CADTutor ernest. I know this is not what you are asking for, but I thought it might include something that would help. Are you talking about converting .DGN or .DNG files? https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2016/ENU/AutoCAD-Core/files/GUID-3F4F7D09-E6A7-444F-B9C3-CA6A6E466DB1-htm.html How many drawings do you need to convert? Check out this lisp by Lee Mac http://www.lee-mac.com/scriptwriter.html Thanks Lee! Edited August 9, 2016 by Dadgad Quote
BIGAL Posted August 9, 2016 Posted August 9, 2016 Just write down the steps and repeat them in simple text file saved as .scr then just type script and load it. I have left out the little sneaky bits of how to make a script in a couple of minutes. dgnimport dwg1.dgn -dxfout dwg1 all close N dgnimport dwg2.dgn -dxfout dwg2 all close N Quote
Dadgad Posted August 9, 2016 Posted August 9, 2016 BIGAL, I think you use scripts a lot, and I never have, but looking at Lee's SCRIPTWRITER lisp, it looks pretty smicko, you can run a single line script on an entire directory without the tedium of all that renaming, which seems typically (Lee Mac) efficient! I think it may look pretty close to the following, which I based on your last post (untested) _.dgnimport *file* _.dxfout *file* _.close Quote
