Does anyone know how I can loop through existing features in an Inventor part file and suppress or delete specific ones as required? I am working in C# and a snippet of code would be appreciated (VB is fine too).
I figured it out. Here is a bit of code showing how.
Notes:
1. You have to loop from the highest possible index backwards to 1 because the highest index no longer exists once you delete an item.
2. You have to know the feature type you are looking for, in this example a hole feature.
int num = partDoc.ComponentDefinition.Features.HoleFeatures.Count;
for (int i = num; i >= 1; i--)
partName = partDoc.ComponentDefinition.Features.HoleFeatures.Name;
if (partName.Contains("Hole1"))
partDoc.ComponentDefinition.Features.HoleFeatures.Delete();
