alot of my lisp routines don't seem to work properly anymore (some commands i need to type twice as the first time it says its an unknown command and other commands just don't work at all - after working fine for years)
all the lisp routines for inserting certain blocks don't work. when i type them it just shows the insert block dialog box instead of inserting the block i want.
and with blocks on my drawing when i double click to edit them the "edit block definition" dialog box appears and it doesn't seem to know which block i want to edit so i have to pick the block from the list, instead of it specifying the block name i've just double clicked in the dialog box by itself like it has always done previously... so confused why/how this started happening. i can't work like this :(
any help would be verrrrry much appreciated!!
