can i reset autocad 2007 to the original default settings i received it with. i think i have changed settings that i shouldn't have maybe. things are just not doing what they should.help!!!!!!!!
thanks in advance, charlie
It's not necessary to post your question multiple times. Just post your question once and wait for replies. Your post will be seen by everyone. :)
Try resetting the profile within the OPTIONS command, back to Vanilla.
Nick
What setting(s) are causing a problem? It may be easier to deal the exact issue and reset one or two settings.. if you don't have a plain profile saved.
  • 1 year later...
So how can i reset AutoCAD 2007 back to the original default setting?
i just want it to be brand new liek fresh install
