Can't get rid of the imageframes
I am using LT2009 on Vista plotting to a Xerox 510.
No matter what the IF setting is 0 or 2 parts of the frame still plot.
They do not plot when using cutePDF writer
What setting in the .pc3 file if any will get rid of the lines?
Also DWG to PDF.pc3 plots too dark. allegedly this was fixed with SP1 for LT2009. Any ideas?
Here is a detour:
To insert images on a single layer. Open properties->general, the color of the frame is set bylayer; open the layer manager and set the layer color to white or the same color as the image's border.
