Muhammad Sadiq Posted August 22, 2016 Posted August 22, 2016 Hey All, How can i print the dwg. without opening??? Advance Thanks, MS Quote
halam Posted August 22, 2016 Posted August 22, 2016 The are tools to automatically save a PDF before closing and there a a bunch of tools that let you script printing multiple files in one go..but I doubt if it technically possible to do it without opening it.. Who needs paper anyway? Quote
TheCADnoob Posted August 22, 2016 Posted August 22, 2016 Something will have to open it to print it. Im not sure of any third party solution to this but there may be one out there. In AutoCAD there is the batch plot option which will allow you to "print with out opening it" but in reality its doing it but just in a manner that is quick an automated. If you are need to get to the drawing with out paying for CAD you can get something like TrueView (http://www.autodesk.com/products/dwg/viewers) it can also batch plot just like AutoCAD but i believe its opening the drawings as well. What issue are you trying to address by not opening the drawing? Quote
vudungcom Posted 1 hour ago Posted 1 hour ago Hello, You can try this app Turbo Plot, by using accore so it supports Headless and multiple workers, it is faster than current software use active X. In setting pls use Acad not Brics. https://drive.google.com/drive/u/1/folders/1ds7cGhJ5FB9hYluPb1ej81CFOsqifPrl Quote
