Charles1234 Posted August 22, 2016 Posted August 22, 2016 I tried to install Trueview 2017, but it caused extremely slow operation of Autocad 2010 (60-240 seconds). It would not even work, so I uninstalled it. Since I installed and uninstalled trueview my express Tools in Autocad has ceased to function or even appear on my menu bar. I tried entering "expresstools" on the command line, but nothing happens. I tried to right click a tool bar, but Expresstools is not listed. the options menu lists the path as C:\program files\autocad 2010\express. There is an Express folder in that location and it is not empty. Why did this happen? How can I fix it? Quote
TheCADnoob Posted August 22, 2016 Posted August 22, 2016 edit: I should say try uninstalling express tools and then reinstalling express tools Give this a shot: https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-install-Express-Tools-into-AutoCAD.html Quote
Cad64 Posted August 22, 2016 Posted August 22, 2016 I'm not sure why you posted this question in the 3ds Max 3D modeling section but I have moved this thread to the Autocad General section: http://www.cadtutor.net/forum/forumdisplay.php?19-AutoCAD-General Quote
BIGAL Posted August 23, 2016 Posted August 23, 2016 Like Remark but its not called express tools its called acetmain.cuix Check your cui a menu can be loaded but not turned on. Quote
