I have been racking my brain trying to figure out how to change the text of a table using script. I started with:
Tabledit
(then it asked me to pick a table cell) and i am stuck..
I have tried different option - 2,A / 2A / A2...etc but have failed miserably. refer to attached image for the table i was trying to edit. just changing the XXX with an actual date.
Any help from 'the experts' will be greatly appreciated.
The command expects a point value.
To edit tables via Lisp code it is better to use the VL functions:
(vla-settext (vlax-ename->vla-object (car (entsel))) 1 0 "20160831")
A different approach we run the table as a multi line block, there has been a few posts about auto updating etc adding a new line etc search here.
Interesting which is correct Issue or the verb Issued.
