handasa Posted September 2, 2016 Posted September 2, 2016 Greetings Everyone i use this vba from excell which wrriten by mr.Christos Samaras this vba draw blocks in the active autocad drawing i want each time i run the vba macro save the drawing as cell A1 content e.g. if the cell A1 is (section1) then the vba save the drawing as (section1.dwg) any help will be appreciated thanks in advance Option Explicit 'A custom type that holds the scale factors of the block. Private Type ScaleFactor X As Double Y As Double Z As Double End Type Sub InsertBlocks() '-------------------------------------------------------------------------------------------------------------------------- 'Inserts blocks in AutoCAD using data - insertion point, block name/full path, scale factors, rotation angle - from Excel. 'Note that the block name or the block path must already exists, otherwise nothing will be inserted. 'The code uses late binding, so no reference to external AutoCAD (type) library is required. 'It goes without saying that AutoCAD must be installed at your computer before running this code. 'Written by: Christos Samaras 'Date: 21/04/2014 'e-mail: xristos.samaras@gmail.com 'site: http://www.myengineeringworld.net '-------------------------------------------------------------------------------------------------------------------------- 'Declaring the necessary variables. Dim acadApp As Object Dim acadDoc As Object Dim acadBlock As Object Dim LastRow As Long Dim i As Long Dim InsertionPoint(0 To 2) As Double Dim BlockName As String Dim BlockScale As ScaleFactor Dim RotationAngle As Double 'Activate the coordinates sheet and find the last row. With Sheets("ADD SECTION") .Activate LastRow = .Cells(.Rows.Count, "A").End(xlUp).Row End With 'Check if there are coordinates for at least one circle. If LastRow < 2 Then MsgBox "There are no coordinates for the insertion point!", vbCritical, "Insertion Point Error" Exit Sub End If 'Check if AutoCAD application is open. If is not opened create a new instance and make it visible. On Error Resume Next Set acadApp = GetObject(, "AutoCAD.Application") If acadApp Is Nothing Then Set acadApp = CreateObject("AutoCAD.Application") acadApp.Visible = True End If 'Check (again) if there is an AutoCAD object. If acadApp Is Nothing Then MsgBox "Sorry, it was impossible to start AutoCAD!", vbCritical, "AutoCAD Error" Exit Sub End If On Error GoTo 0 'If there is no active drawing create a new one. On Error Resume Next Set acadDoc = acadApp.ActiveDocument If acadDoc Is Nothing Then Set acadDoc = acadApp.Documents.Add End If On Error GoTo 0 'Check if the active space is paper space and change it to model space. If acadDoc.ActiveSpace = 0 Then '0 = acPaperSpace in early binding acadDoc.ActiveSpace = 1 '1 = acModelSpace in early binding End If On Error Resume Next 'Loop through all the rows and add the corresponding blocks in AutoCAD. With Sheets("ADD SECTION") For i = 2 To LastRow 'Set the block name. BlockName = .Range("D" & i).Value 'If the block name is not empty, insert the block. If BlockName <> vbNullString Then 'Set the insertion point. InsertionPoint(0) = .Range("A" & i).Value InsertionPoint(1) = .Range("B" & i).Value InsertionPoint(2) = .Range("C" & i).Value 'Initialize the optional parameters. BlockScale.X = 1 BlockScale.Y = 1 BlockScale.Z = 1 RotationAngle = 0 'Set the optional parameters (if there are values on the corresponding ranges). If .Range("E" & i).Value <> vbNullString Then BlockScale.X = .Range("E" & i).Value If .Range("F" & i).Value <> vbNullString Then BlockScale.Y = .Range("F" & i).Value If .Range("G" & i).Value <> vbNullString Then BlockScale.Z = .Range("G" & i).Value If .Range("H" & i).Value <> vbNullString Then RotationAngle = .Range("H" & i).Value 'Add the block using the sheet data (insertion point, block name, scale factors and rotation angle). 'The 0.0174532925 is to convert degrees into radians. Set acadBlock = acadDoc.ModelSpace.InsertBlock(InsertionPoint, BlockName, _ BlockScale.X, BlockScale.Y, BlockScale.Z, RotationAngle * 0.0174532925) End If Next i End With 'Zoom in to the drawing area. acadApp.ZoomExtents 'Release the objects. Set acadBlock = Nothing Set acadDoc = Nothing Set acadApp = Nothing 'Inform the user about the process. MsgBox "The blocks were successfully inserted in AutoCAD!", vbInformation, "Finished" End Sub Sub ClearAll() Dim LastRow As Long 'Find the last row and clear all the input data.. With Sheets("ADD SECTION") .Activate LastRow = .Cells(.Rows.Count, "A").End(xlUp).Row .Range("A2:H" & LastRow).ClearContents .Range("A2").Select End With End Sub Quote
