desbou Posted September 2, 2016 Posted September 2, 2016 Hello! When rendering my simple house project (I'm a 3d beginner ), my walls appear transparent. At the same time the material applied to them looks black in the materials browser list, as well as in the materials editor. I attempt to delete the material and start from dublicating "global", but then I get a FATAL ERROR message and Autocad (2014) closes unexpectingly ... Any thoughts, please? Quote
Cad64 Posted September 3, 2016 Posted September 3, 2016 What material are you applying to the walls? It sounds like maybe you have some corruption in your file. Try running an AUDIT to fix any errors. Quote
desbou Posted September 3, 2016 Author Posted September 3, 2016 Unfortunatelly, neither AUDIT nor RECOVER can detect and fix any errors..I tried both, but no luck The material I'm applying to the walls is Stucco Exterior Beige. Its appearance picture has changed, as well as its properties. When deleting the material, AUTOCAD crashes. Quote
Cad64 Posted September 3, 2016 Posted September 3, 2016 Why don't you just leave that material alone and create a new material. Don't try and duplicate any existing materials, create a brand new material. Apply the new material to your model and then run the PURGE command and purge all unused materials. Quote
desbou Posted September 8, 2016 Author Posted September 8, 2016 Thank you so much for your time! The truth is that I was lucky enough to have another copy of that drawing, so after trying all those tricks (that unfortunately didn't work, because the file was so much damaged), I finally deleted the file and worked with the copy. Quote
ReMark Posted September 8, 2016 Posted September 8, 2016 It sounds to me as though you had a corrupted drawing and that there was nothing inherently wrong with AutoCAD itself. Quote
Cad64 Posted September 8, 2016 Posted September 8, 2016 I finally deleted the file and worked with the copy. This is why I always tell people to save copies as they work. That way, if a file becomes corrupted somehow, (which does happen sometimes), you always have a previous copy to go back to. You might lose a little work, but it's better than losing all your work. Quote
MillerMG Posted September 9, 2016 Posted September 9, 2016 This is why I always tell people to save copies as they work. That way, if a file becomes corrupted somehow, (which does happen sometimes), you always have a previous copy to go back to. You might lose a little work, but it's better than losing all your work. I couldn't agree more. We had a site plan go corrupt out of no where and made it impossible to work in. If you selected anything, and i mean anything, there was a minimum of a 10 sec delay before you could do anything, once you invoked a command it was another min. of 10 sec. Those 10 sec add up quick. Quote
