Spaj Posted September 3, 2016 Posted September 3, 2016 Hi I'm trying to put together a LISP routine that will tabulate specific properties of numerous specific dynamic blocks in a drawing. I have manged to find the code below (Thanks to Fixo? and HMSilva) which has been modified to only recognize XRefed blocks. How do I remove the logic that tests for this? I have identified the code (IsXref) which test for this condition but how to eliminate this eludes me. Eventually I would like to include the co-ordinates of the start and end of each block in the table. ;| http://www.cadtutor.net/forum/showthread.php?83991-Populate-Table Original by Oleg Fateev Modified by hms 2014/11/14 as a 'demo' to JCprog http://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/extract-attributes-from-a-specific-block-and-write-to-table/m-p/5399759#U5399759 |; (defun C:CLIST (/ a1 a2 a3 acapp acsp adoc atable attdata atts col headers pt row title) (or adoc (setq adoc (vla-get-activedocument (setq acapp (vlax-get-acad-object)))) ) (or acsp (setq acsp (vla-get-block (vla-get-activelayout adoc))) ) (vlax-for blk (vla-get-blocks adoc) (if (= (vla-get-IsXref blk) :vlax-true) ;<-*** (vlax-for x blk (if (and (= (vla-get-ObjectName x) "AcDbBlockReference") (wcmatch (vla-get-EffectiveName x) "*|Duct") ) (progn (setq atts (vlax-invoke x 'getattributes)) (foreach att atts (cond ((wcmatch (vla-get-tagstring att) "DUCT_START") (setq a1 (vla-get-textstring att)) ) ((wcmatch (vla-get-tagstring att) "DUCT_END") (setq a2 (vla-get-textstring att)) ) ((wcmatch (vla-get-tagstring att) "DUCTTYPE") (setq a3 (vla-get-textstring att)) ) ) ) (setq attdata (cons (list a1 a2 a3) attdata)) ) ) ) ) (if (setq pt (getpoint "\nSpecify table location:")) (progn (setq atable (vla-addtable acsp (vlax-3d-point pt) (+ 2 (length attdata)) 3 (/ (getvar 'dimtxt) 2) (* (getvar 'dimtxt) 4) ) ) (vla-put-regeneratetablesuppressed atable :vlax-true) (setq col 0) (foreach wid (list 10.0 10.0) (vla-setcolumnwidth atable col wid) (setq col (1+ col)) ) (vla-put-horzcellmargin atable 0.3) (vla-put-vertcellmargin atable 0.3) (vla-setTextheight atable 1 2.0) (vla-setTextheight atable 2 1.4) (vla-setTextheight atable 4 1.4) (setq title "DUCTS") (vla-setText atable 0 0 title) (vla-setcelltextheight atable 0 0 2.0) (vla-SetCellAlignment atable 0 0 acMiddleCenter) (setq headers (list "START" "END" "TYPE")) (setq row 1 col 0 ) (repeat (length headers) (vla-SetCellAlignment atable row col acMiddleCenter) (vla-setcelltextheight atable row col 1.4) (vla-setText atable row col (car headers)) (setq headers (cdr headers)) (setq col (1+ col)) ) (setq row 2) (foreach record attdata (setq col 0) (foreach item record (vla-setText atable row col item) (vla-SetCellAlignment atable row col acMiddleCenter) (vla-setcelltextheight atable row col 1.4) (setq col (1+ col)) ) (setq row (1+ row)) ) (vla-put-regeneratetablesuppressed atable :vlax-false) (vla-put-height atable (+ (* (vla-get-rows atable) 2.2) 4.1)) (vla-update atable) ) ) (princ) ) (prompt "\n\t---\tStart command with CLIST\t---\n") (prin1) (or (vl-load-com)) (princ) Quote
Dadgad Posted September 4, 2016 Posted September 4, 2016 Have you checked out http://www.lee-mac.com/dynamicblockcounter.html ? Sounds like pretty much what you are looking for. Thanks Lee! Quote
Spaj Posted September 4, 2016 Author Posted September 4, 2016 Hi Yep, I looked at this for pointers, but the code above is closer to what I need. Quote
Tharwat Posted September 5, 2016 Posted September 5, 2016 Hi, Can you give an example of the final result of the table including the coordinates via an image or a drawing? Quote
Spaj Posted September 5, 2016 Author Posted September 5, 2016 Hi Tharwat Attached is an example. The idea is to extract the data from the dynamic blocks and tabulate as shown in the example. Note that the tabulated co-ords are transposed and signed as a result of our south orientated survey system. Ducts Example.dwg Thanks for your interest. Quote
BIGAL Posted September 5, 2016 Posted September 5, 2016 Here is a table create example my be helpful. ; dwg index to a table ; by Alan H NOV 2013 (defun AH:dwgindex (/ doc objtable ss1 lay ans ans2 plotabs ss1 tag2 tag3 list1 list2 curlayout colwidth numcolumns numrows INC rowheight ) (vl-load-com) (setq curlayout (getvar "ctab")) (if (= curlayout "Model") (progn (Alert "You need to be in a layout for this option") (exit) ) ; end progn ) ; end if model (setq doc (vla-get-activedocument (vlax-get-acad-object))) (setq curspace (vla-get-paperspace doc)) (setq pt1 (vlax-3d-point (getpoint "\nPick point for top left hand of table: "))) ; read values from title blocks (setq bname "DA1DRTXT") (setq tag2 "DRG_NO") ;attribute tag name (setq tag3 "WORKS_DESCRIPTION") ;attribute tag name (setq ss1 (ssget "x" (list (cons 0 "INSERT") (cons 2 bname)))) (if (= ss1 nil) ; for xxx jobs (progn (setq bname "XXXX_TITLE") (setq ss1 (ssget "x" (list (cons 0 "INSERT") (cons 2 bname)))) ) ) (setq INC (sslength ss1)) (repeat INC (foreach att (vlax-invoke (vlax-ename->vla-object (ssname SS1 (SETQ INC (- INC 1)) )) 'getattributes) (if (= tag2 (strcase (vla-get-tagstring att))) (progn (setq ans (vla-get-textstring att)) (if (/= ans NIL) (setq list1 (cons ans list1)) ) ; if ); end progn ) ; end if (if (= tag3 (strcase (vla-get-tagstring att))) (progn (setq ans2 (vla-get-textstring att)) (if (/= ans2 NIL) (setq list2 (cons ans2 list2)) ) ; end if ) ; end progn ) ; end if tag3 ) ; end foreach ) ; end repeat (setvar 'ctab curlayout) (command "Zoom" "E") (command "regen") (reverse list1) ;(reverse list2) ; now do table (setq numrows (+ 2 (sslength ss1))) (setq numcolumns 2) (setq rowheight 0.2) (setq colwidth 150) (setq objtable (vla-addtable curspace pt1 numrows numcolumns rowheight colwidth)) (vla-settext objtable 0 0 "DRAWING REGISTER") (vla-settext objtable 1 0 "DRAWING NUMBER") (vla-settext objtable 1 1 "DRAWING TITLE") (SETQ X 0) (SETQ Y 2) (REPEAT (sslength ss1) (vla-settext objtable Y 0 (NTH X LIST1)) (vla-settext objtable Y 1 (NTH X LIST2)) (vla-setrowheight objtable y 7) (SETQ X (+ X 1)) (SETQ Y (+ Y 1)) ) (vla-setcolumnwidth objtable 0 55) (vla-setcolumnwidth objtable 1 170) (command "_zoom" "e") ); end AH defun (AH:dwgindex) (princ) Quote
Spaj Posted September 6, 2016 Author Posted September 6, 2016 Hi Thanks for the input, but it's more the extraction of data from the Dynamic blocks that I'm battling with. Quote
Tharwat Posted September 9, 2016 Posted September 9, 2016 Hi Tharwat Attached is an example. The idea is to extract the data from the dynamic blocks and tabulate as shown in the example. Note that the tabulated co-ords are transposed and signed as a result of our south orientated survey system. Thanks for your interest. Spaj, please give a clear explanation for one block with its coordinates as shown in the table and when to add minus or plus symbols. Quote
Spaj Posted September 9, 2016 Author Posted September 9, 2016 Hi Tharwat Sorry for the confusion. Attached is an example. Simply put, co-ords generated in AutoCAD need to be transposed ie X becomes the Y value and Y becomes the X value, but with the opposite signs. Ducts Example1.dwg This is due to the non standard survey co-ord system in SA which is south orientated and angular measure is anti-clockwise with co-ords quoted Y then X. The best compromise in AutoCAD is to work in the 3rd quadrant cartesian system (where X and Y values are -ve). This allows for the correct orientation, the correct sequence of co-ordinate values, but with the drawback of the values having the incorrect sign. Therefore all quoted co-ords need to be transposed and signed. Quote
Spaj Posted September 25, 2016 Author Posted September 25, 2016 Hi Do you perhaps know how to eliminate the logic to check that the block is an XRef in the attached code? (defun C:CLIST (/ a1 a2 a3 acapp acsp adoc atable att attdata atts blk col coords headers pt row title x) (or adoc (setq adoc (vla-get-activedocument (setq acapp (vlax-get-acad-object)))) ) (or acsp (setq acsp (vla-get-block (vla-get-activelayout adoc))) ) (vlax-for blk (vla-get-blocks adoc) (if (/= (vla-get-IsXref blk) :vlax-true) ;<----- (vlax-for x blk (if (and (= (vla-get-ObjectName x) "AcDbBlockReference") (wcmatch (vla-get-EffectiveName x) "*|Duct") ) (progn (setq atts (vlax-invoke x 'getattributes)) (foreach att atts (cond ((wcmatch (vla-get-tagstring att) "DUCT_START") (setq a1 (vla-get-textstring att)) ;(setq coordStart (vlax-get att insertionpoint)) ) ((wcmatch (vla-get-tagstring att) "DUCT_END") (setq a2 (vla-get-textstring att)) ;(setq coordEnd (vlax-get att insertionpoint)) ) ((wcmatch (vla-get-tagstring att) "DUCT_TYPE") (setq a3 (vla-get-textstring att)) ) ) ;end Cond ) ; end ForEach (setq attdata (cons (list a1 a2 a3) attdata)) ) ; end Progn ); end If ) ; end for ) ;end if ) ;end For Thanks Quote
Lee Mac Posted September 25, 2016 Posted September 25, 2016 Comment the if statement and the corresponding closing parenthesis (comment lines 10 & 35), and remove the pipeline character from the wcmatch expression. Quote
marko_ribar Posted September 25, 2016 Posted September 25, 2016 Lee was quicker... As a portion of bigger code, I think this remove logic of checking if object is Xref... (defun C:CLIST (/ a1 a2 a3 acapp acsp adoc atable att attdata atts blk col coords headers pt row title x ) (vl-load-com) (or adoc (setq adoc (vla-get-activedocument (setq acapp (vlax-get-acad-object))) ) ) (or acsp (setq acsp (vla-get-block (vla-get-activelayout adoc))) ) (vlax-for blk (vla-get-blocks adoc) (vlax-for x blk (if (and (= (vla-get-ObjectName x) "AcDbBlockReference") (= (strcase (vla-get-EffectiveName x)) "DUCT") ) (progn (setq atts (vlax-invoke x 'getattributes)) (foreach att atts (cond ((wcmatch (vla-get-tagstring att) "DUCT_START") (setq a1 (vla-get-textstring att)) ;(setq coordStart (vlax-get att insertionpoint)) ) ((wcmatch (vla-get-tagstring att) "DUCT_END") (setq a2 (vla-get-textstring att)) ;(setq coordEnd (vlax-get att insertionpoint)) ) ((wcmatch (vla-get-tagstring att) "DUCT_TYPE") (setq a3 (vla-get-textstring att)) ) ) ;end Cond ) ; end ForEach (setq attdata (cons (list a1 a2 a3) attdata)) ) ; end Progn ) ; end If ) ; end for ) ;end For ... Quote
Tharwat Posted September 26, 2016 Posted September 26, 2016 What is the use of or function as long as the variable is localised? Quote
Spaj Posted September 26, 2016 Author Posted September 26, 2016 Hi Lee Comment the if statement and the corresponding closing parenthesis (comment lines 10 & 35), and remove the pipeline character from the wcmatch expression. Thanks, that worked. I had the comment out the if statement and corresponding parenthesis But not the pipeline! What is the significance of the pipeline? Unfortunately I now have an ActiveX Server returned an error: Parameter not optional from the remainder of the code. Quote
Spaj Posted September 26, 2016 Author Posted September 26, 2016 Hi Marko Thanks for the input, but that did not seem to work. The routine does not recognize the specified blocks. Quote
Lee Mac Posted September 26, 2016 Posted September 26, 2016 What is the significance of the pipeline? Table names (i.e. layers, blocks, linetypes etc.) which contain the pipe character are xref-dependent items, with the content to the left of the pipe equal to the name of the xref from which they are derived. Unfortunately I now have an ActiveX Server returned an error: Parameter not optional from the remainder of the code. Can you post your current modified code? Quote
Spaj Posted September 26, 2016 Author Posted September 26, 2016 Table names (i.e. layers, blocks, linetypes etc.) which contain the pipe character are xref-dependent items, with the content to the left of the pipe equal to the name of the xref from which they are derived. Aha, helps if you understand these nuances. Can you post your current modified code? Sure... CList_Duct.LSP Quote
Lee Mac Posted September 27, 2016 Posted September 27, 2016 Without testing the code, I suspect that the error arises because one of the attribute values is null, as the variables holding each attribute value are not tested for validity following evaluation of the foreach loop before being pushed onto the main data list: (progn (setq atts (vlax-invoke x 'getattributes)) (foreach att atts (cond ((wcmatch (vla-get-tagstring att) "DUCT_START") (setq a1 (vla-get-textstring att)) ;(setq coordStart (vlax-get att insertionpoint)) ) ((wcmatch (vla-get-tagstring att) "DUCT_END") (setq a2 (vla-get-textstring att)) ;(setq coordEnd (vlax-get att insertionpoint)) ) ((wcmatch (vla-get-tagstring att) "DUCT_TYPE") (setq a3 (vla-get-textstring att)) ) ) ;end Cond ) ; end ForEach (setq attdata (cons (list [highlight]a1 a2 a3[/highlight]) attdata)) ) An easy way to test this theory is to print the value of attdata after evaluation of the outer vlax-for loop. Quote
Spaj Posted September 28, 2016 Author Posted September 28, 2016 Without testing the code, I suspect that the error arises because one of the attribute values is null, as the variables holding each attribute value are not tested for validity following evaluation of the foreach loop before being pushed onto the main data list. An easy way to test this theory is to print the value of attdata after evaluation of the outer vlax-for loop. Correct, one of the block attribute names did not correspond with the name in the foreach loop. Thank you kindly for the help. Quote
