Hi,
How can i convert 3d dwg files to obj or 3ds ? I am not very good at using the program so is it easy to do it?
You can't convert them to obj of 3ds.
Use the EXPORT command to see what formats are available.
What program are you trying to take your dwg into?
I am trying to open them in blender. That is Why I need them obj or 3ds
The ability to export to the 3ds file format was supported in releases of AutoCAD prior to 2007 then it was expunged. Use the -FBXEXPORT command instead.
From the AutoCAD Help file:
So I can Export dwg files to fbx? Is it easy to do that? Because I really dont know How to use the program
