cybernovirus Posted September 13, 2016 Posted September 13, 2016 Hi, I'm new to AutoCAD and with a little help from tutorial I was successfully make a toy car model for my project But I have a problem when I want to print the chassis of the car I want to print the chassis using top view of the model with 1:1 scale. The acrylic printer only provide .cdr format for its printing media How can I 'export' my top view of model to .cdr format with 1:1 scale? Sorry for not providing a screenshoot because I'm using a mobile phone Quote
ReMark Posted September 13, 2016 Posted September 13, 2016 First off you cannot export an AutoCAD drawing to the .cdr file type. Do you have access to CorelDraw? If you have a relatively newer version of the program you should be able to import the .dwg file into the program then save it as a .cdr file. Older versions of CorelDraw will import .dxf files so keep that in mind as well. Quote
