sean112 Posted September 15, 2016 Posted September 15, 2016 Hello guys, Is there a way to convert something like ("Sean") into just "Sean"? It is probably a trivial question. Thanks in advance, Sean Quote
BKT Posted September 15, 2016 Posted September 15, 2016 Hi Sean, If you've already set ("Sean") to some variable you could just do a CAR on it: (setq lst ("Sean")) (car lst) will result in "Sean". BKT Quote
BIGAL Posted September 15, 2016 Posted September 15, 2016 Seans 1st name is (setq lst (list "seans" "1st" "name " "is")) (car lst) "seans" (nth 1 lst) "1st" (caddr lst) "name" (nth 3 lst) "Is" Quote
sean112 Posted September 15, 2016 Author Posted September 15, 2016 Thanks, this term is actually peeled of from cdr of a cons function. I completely did no expect realize I can simply use another car to get the string out. Quote
Lee Mac Posted September 15, 2016 Posted September 15, 2016 Thanks, this term is actually peeled of from cdr of a cons function. I completely did no expect realize I can simply use another car to get the string out. In this case, use cadr to return the second item in your list: (cadr <list>) = (car (cdr <list>)) Quote
