masterfal Posted September 15, 2016 Posted September 15, 2016 Hi All, Been looking for something to allow me to import all layouts from a specific template via a lisp command. I managed to find the code below which works great, but it only imports 1 layout at a time. Can the code below be amended to include other layouts from that template also? (layout names S1, S2, S3 etc up to S9) I tried throwing in an extra layout name to see if it would work by doing it like: ....../A4 DETAILS.dwt" "S1, S2") but it only imports S1 Or if it cant be amended does anyone know of anything else? I've found lee macs "steal" lisp which is also excellent, but it does a little more than what I need.. Specifying which layouts isn't required really (unless they need to be specified for it to work of course), just want it to import all if possible (defun c:S1 () (setvar "cmdecho" 0) (command "-layout" "template" "Z:/Engineering/00 LIBRARY/Drafting Resources/_Launchers/A4 DETAILS.dwt" "S1") (setvar "cmdecho" 1) (princ) ) Quote
Tharwat Posted September 15, 2016 Posted September 15, 2016 Hi, Try to iterate through a list and I think it should work. eg: (setvar "cmdecho" 0) (foreach layout '("S1" "S2" "S3") (command "-layout" "template" "Z:/Engineering/00 LIBRARY/Drafting Resources/_Launchers/A4 DETAILS.dwt" layout) ) (setvar "cmdecho" 1) Quote
masterfal Posted September 15, 2016 Author Posted September 15, 2016 Hi, Try to iterate through a list and I think it should work. eg: (setvar "cmdecho" 0) (foreach layout '("S1" "S2" "S3") (command "-layout" "template" "Z:/Engineering/00 LIBRARY/Drafting Resources/_Launchers/A4 DETAILS.dwt" layout) ) (setvar "cmdecho" 1) Tharwat, you are a superstar.. Helped out again with exactly what I was after. Thankyou so much! Quote
Tharwat Posted September 15, 2016 Posted September 15, 2016 Tharwat, you are a superstar.. Helped out again with exactly what I was after. Thankyou so much! You are most welcome. Quote
