jonathann3891 Posted January 8, 2009 Posted January 8, 2009 Hi everbody! I've visted this forum many times, but this is my first post. I recently starting having some real issues with autocad, whether it be basic CAD or LDD. I get the same errors on startup. I hope you guys can help! Here is my log Customization file loaded successfully. Customization Group: ACAD Customization file loaded successfully. Customization Group: CUSTOM Customization file loaded successfully. Customization Group: IMPRESSION Customization file loaded successfully. Customization Group: VAULT Customization file loaded successfully. Customization Group: EXPRESS Regenerating model. Initializing........ C:\Program Files\AutoCAD Civil 3D 2008\AcMapWorkspace.arx cannot find a dll or other file that it needs. . C:\Program Files\AutoCAD Civil 3D 2008\AcMapDwfApi.arx cannot find a dll or other file that it needs. Failed. AcMapWorkspace.arx Load Failed AcMapDwfApi.arx Load Failed C:\Program Files\AutoCAD Civil 3D 2008\AcMapDwfUI.arx cannot find a dll or other file that it needs. C:\Program Files\AutoCAD Civil 3D 2008\Civil\AeccUiModel.arx cannot find a dll or other file that it needs. AutoCAD Express Tools Copyright © 2002-2004 Autodesk, Inc. ; error: AutoCAD variable setting rejected: "cmdecho" nil AutoCAD menu utilities loaded.; error: bad argument type: stringp nil Command: COMMANDLINE Command: properties Command: DASHBOARD I'm when I open a drawing, it ask me to select an object when I have not entered a command. Here is the log for that AutoCAD menu utilities loaded.Unknown command "DEFINE". Press F1 for help. *Invalid selection* Expects a point or Last/ALL/Group ; error: Function cancelled Select object: Autodesk DWG. This file is a TrustedDWG last saved by an Autodesk application or Autodesk licensed application. Thanks! Quote
Attila The Gel Posted January 8, 2009 Posted January 8, 2009 Welcome to the forum, I dont work with Civil 3D but to start... Checked if the files that can't be found are in the windows folder mentioned? Check if these files AcMapWorkspace.arx AcMapDwfApi.arx AcMapDwfUI.arx *AeccUiModel.arx are in this folder? C:\Program Files\AutoCAD Civil 3D 2008\(*Civil) Quote
jonathann3891 Posted January 8, 2009 Author Posted January 8, 2009 Yes they are all located in that folder. Quote
BenE Posted January 8, 2009 Posted January 8, 2009 If you right click on the AutoCad icon and select properties, in the box labeled target does it show the correct profile? For example, mine shows "C:\Program Files\AutoCAD Civil 3D 2008\acad.exe" /p ">" to load my standard profile. I had a similar thing happen while back, and correcting this fixed my problem. http://www.cadtutor.net/forum/showthread.php?t=26481 Quote
rkmcswain Posted January 9, 2009 Posted January 9, 2009 I recently starting having some real issues with autocad, whether it be basic CAD or LDD. I get the same errors on startup. I hope you guys can help! Without doing any research (i.e. just a guess), I would say that your support file search paths are hosed... Have you checked this?Have you run a repair on your install? Quote
