All,
Good morning. I have something very strange going on here at work using Autocad 2014 on Dell T3500 workstation. If I open multiple drawings and when I click on file tab and go back to drawing, everything is gone, just a black screen. I also have tried using the tab in my taskbar with same results. It doesn't happen when my coworkers have multiple drawings open. I am baffled. Any help, fix or suggestions would be greatly appreciated.
thanks in advance,
David
Did you try shutting AutoCAD down then restarting?
This is called the singularity convergence issue. There is nothing you can do to correct it but if you sit long enough and stare at the screen you will enter a new dimension. Be careful once you enter this new world finding your way back can be difficult.
Solved.....I updated NVIDIA graphics card driver and it's working now.
