Soposcrin Posted September 23, 2016 Posted September 23, 2016 Hello I am trying to find a free download of a vehicle turning simulator, I tried one called thru glamsen, doesn't seem to get past download, anyone with any ides? Quote
halam Posted September 23, 2016 Posted September 23, 2016 Hi there Sopos http://www.glamsen.se/CadTools.htm had some Nice features incl vehicle tracking Quote
halam Posted September 23, 2016 Posted September 23, 2016 Sorry i See now that is the one You tried.. ;-) whats wrong with it? Quote
Soposcrin Posted September 23, 2016 Author Posted September 23, 2016 When I launch CadTools.exe and then run it, it tells me Run-time error '339 Component 'MSCOMCTL.OCX' or one of its dependencies not correctly registered: a file is missing or invalid Quote
MillerMG Posted September 23, 2016 Posted September 23, 2016 Hi there Soposhttp://www.glamsen.se/CadTools.htm had some Nice features incl vehicle tracking We have been using the same one. I started a thread a while back about this. The ones that halam cited worked out perfect for turn analysis of different types of vehicles. Setting up the vehicle to your exact dim can be a little bit tricky at first but is a breeze once its figured out. Sorry to hear that it did not work out for you. Are you sure that you are using the correct one? If you are use AutoCad 14, is that the one you downloaded? Quote
MillerMG Posted September 23, 2016 Posted September 23, 2016 http://www.cadtutor.net/forum/showthread.php?87373-Civil-Question-Turning-Template-Please-Help! This was the thread that I started a while back that I referenced above Quote
