doronz Posted September 29, 2016 Posted September 29, 2016 (edited) Hello all, I have a drawing of a rail with holes in it. The holes at the edges are Fixed with fixed length, in the middle the distance between each hole is changing when i change the Length of the rail, but cant pass 40 cm from each outher(the divide needs to be equal between the middle holes) Any way to make the same calculate with the dynamic block? In outher simple words i need dynamic divide in the dynamic block Thank you, Doron:) Drawing1.dwg Edited September 29, 2016 by doronz more info Quote
Ski_Me Posted September 29, 2016 Posted September 29, 2016 Do you need more holes to be created as you stretch the block and you need them to be equal distance apart? Quote
Ski_Me Posted September 29, 2016 Posted September 29, 2016 Not sure if this is what your looking for but it's a start. It's not a solution but should get you on the right track. Rail.dwg Quote
BIGAL Posted September 30, 2016 Posted September 30, 2016 Pretty sure same question has been answered here before where as you stretch extra holes are added based on a center point but has a max end distance to the hole. Any one remember ? Quote
doronz Posted October 5, 2016 Author Posted October 5, 2016 wow thank you for the help... Ski_Me the attached you post was very close but the holes need to be divided in center until the distance passes the 40 cm after it passes another hole is created ,and on and on... Rail.dwg Quote
BIGAL Posted October 5, 2016 Posted October 5, 2016 I was hoping someone would remember the older post. Whilst dynamic blocks is the way to go you can do the same old fashioned way with a lisp. Ask a few questions and draw it. (A-300)/400= howmany holes. Quote
doronz Posted October 5, 2016 Author Posted October 5, 2016 http://forums.autodesk.com/t5/dynamic-blocks/need-equal-distances-that-all-depend-on-a-base-distance-between/td-p/6546727 this is what i need.. but when i try to make it on my draw its not working and the lines mix Test Block Window -.dwg Quote
doronz Posted October 5, 2016 Author Posted October 5, 2016 http://forums.autodesk.com/t5/dynamic-blocks/need-equal-distances-that-all-depend-on-a-base-distance-between/td-p/6546727this is what i need.. but when i try to make it on my draw its not working and the lines mix [ATTACH]59413[/ATTACH] Test Block Window -.dwg Did it Thank you all for the help sorry for double posting Quote
kamijin Posted October 10, 2016 Posted October 10, 2016 Well Done dorozn. May i ask how you link visibility and the distance1 parameter? Quote
kuyamac Posted October 10, 2016 Posted October 10, 2016 http://www.cadtutor.net/forum/showthread.php?97021-Dynamic-block-with-stretch-amp-array-on-two-planes-array-position-errors-please-help&highlight=stretch+array this one with fixed distance between holes Quote
