Casio47 Posted September 29, 2016 Posted September 29, 2016 Howdy... I have two .dwg files open (one on each monitor). How do I copy multiple objects from one file to another, and maintain the proper scale. For example, if one table is 6' x 3', how would it remain the same dimension when placed into the 2nd CAD file? Thanks Quote
ReMark Posted September 29, 2016 Posted September 29, 2016 You are drawing all objects FULL size are you not? You aren't scaling your drawings as one might do in manual drafting are you? Quote
Casio47 Posted September 29, 2016 Author Posted September 29, 2016 Correct, all components are 1:1 Quote
Casio47 Posted September 29, 2016 Author Posted September 29, 2016 Never Mind...I wasn't using the copy & paste from the Windows keyboard (Ctrl. + C then Ctrl. + V), I was trying the AutoCAD copy and paste, and it wasn't making the transition to the second monitor. Quote
RobDraw Posted September 29, 2016 Posted September 29, 2016 AutoCAD uses the clipboard for copy/paste, same as Windows. If you are referring to AutoCAD's COPY command, that will only work within the same file. Quote
Casio47 Posted September 29, 2016 Author Posted September 29, 2016 AutoCAD's COPY command, that will only work within the same file.[code] I believe I discovered that...thanks! Quote
RobDraw Posted September 29, 2016 Posted September 29, 2016 I believe I discovered that...thanks! I don't think so. Many others have "discovered" it before you. Quote
BIGAL Posted September 30, 2016 Posted September 30, 2016 Just a side issue if you "Insert" another dwg into current dwg you sometimes get a odd scaling problem so need to make sure insert dwg has the same dwg settings as the target. We get this occasionally as a scale factor of 0.3048 which is feet v's metric. Its not just Units but also check Aecdwgsetup in both. Quote
