andr3flaviano
Lisp for insert text at a specific point
andr3flaviano
Hello, Guys!
I need a litte help in a very easy question about Lisp
I need a Lisp for insert a especific text at a especific point in autocad...
Example: I want to write the number 5 at the point:
x = 3
y = 2
It's easy, but i don't now how to input the coordinates of the text
Could Someone help me, please??
Share this post
Link to post
BIGAL
Easy
; based on some form of values being obtained.
(setq x 3)
(setq y 2)
(setq ans "5")
(command "Text" (list x y) 0.25 0 ans)
Share this post
Link to post
lrm
Bigal, your program will work if the default text height is 0.0 but will place the text "0" if the text height is > 0.0. The text command has one less prompt if the default text height is not 0.0. Is there a way to check for the default text height.
~Lee
Share this post
Link to post
BIGAL
Lrm you are correct there are two methods to Text one with a preset height the other with height=0.0 There is a couple of ways around this. Its always difficult when posting example code to do with text to know which way to post. As a generic approach at work we set the text style to a preset style in our dwt then we know if height is 0.0 or not.
; example of checking current text style has a preset height.
    (setq ts (cdr (assoc 40 (tblsearch "STYLE" (getvar "TEXTSTYLE")))))
    (if (zerop ts)
          (command "TEXT" "498,18" "3.5" "0" ans)
          (command "TEXT" "498,18" "0" ans)
Share this post
Link to post
lrm
Thanks BIGAL, this is something that has stymied me for a long time.
Share this post
Link to post
