Hello everybody,
Im quite new to LISP coding, and mostly i create the tools with copy-pasting and trial and error. tho the case below i cannot solve myself.
I want to command TESTLISP to reload a .lin and a .shx file. This is working.
Now i want to do a 'Layer change', where is replace the linetypes of all layers for other specified ones.
When i use the code below, the LISP doesnt run 'LAYERCHANGER'.
When i add 'C:' to make LAYERCHANGER a command for itself, then it WILL work. (Marked in red)
How can i merge the code from the LAYERCHANGER within the code of 'TESTLISP'.
Note: this is a part of a must lager code, but this is the only part thats failing.
Hope someone can help.
(defun c:TESTLISP ()
(princ "\nHB Huisstyle vervangen...")
(setvar "CMDECHO" 0)
(princ "\nAanpassen shape files...")
(command "LOAD" "HBShapes.shx")
(while (> (getvar"cmdactive") 0) (command ""))
(princ "\nAanpassen linetype files...")
(command "-linetype" "L" "*" "HBLinetypes.lin")
(princ "\nAanpassen linetypes van layers...")
[b](vl-vbarun "LAYERCHANGER" )[/b]
(vl-load-com)
(defun [color="red"]C:[/color]LAYERCHANGER (/ put_linetype linetypes ltyp ltyps)
(vl-load-com)
(or adoc (setq adoc (vla-get-activedocument (vlax-get-acad-object))))
(setq linetypes (vla-get-linetypes adoc))
(vlax-for ltyp (vla-get-linetypes adoc)
(setq ltyps (cons (vla-get-name ltyp) ltyps))
(defun put_linetype (obj linetype linefile)
(if (vl-position linetype ltyps)
(vla-put-linetype obj linetype)
(vla-load linetypes linetype linefile)
(setq ltyps (cons linetype ltyps))
(vla-put-linetype lay linetype)
(vlax-for lay (vla-get-layers adoc)
(cond ((wcmatch (setq ltyp (vla-get-linetype lay)) "PERSRIOOL1")
(vla-put-linetype lay "PERSRIOOL")
((wcmatch (setq ltyp (vla-get-linetype lay)) "50-50")
(put_linetype lay "50-50_200" "HBLinetypes.lin")
((wcmatch (setq ltyp (vla-get-linetype lay)) "100-100")
(put_linetype lay "100-100_200" "HBLinetypes.lin")
((wcmatch (setq ltyp (vla-get-linetype lay)) "05-05_200")
((wcmatch (setq ltyp (vla-get-linetype lay)) "05-05_500")
(put_linetype lay "50-50_500" "HBLinetypes.lin")
((wcmatch (setq ltyp (vla-get-linetype lay)) "HBFENCELINE3")
(put_linetype lay "FENCELINE3" "HBLinetypes.lin")
((wcmatch (setq ltyp (vla-get-linetype lay)) "HBFENCELINE4")
(put_linetype lay "FENCELINE4" "HBLinetypes.lin")
((wcmatch (setq ltyp (vla-get-linetype lay)) "HBFENCELINE5")
(put_linetype lay "FENCELINE5" "HBLinetypes.lin")
((wcmatch (setq ltyp (vla-get-linetype lay)) "HBFENCELINE6")
(put_linetype lay "FENCELINE6" "HBLinetypes.lin")
((wcmatch (setq ltyp (vla-get-linetype lay)) "HBFENCELINE7")
(put_linetype lay "FENCELINE7" "HBLinetypes.lin")
((wcmatch (setq ltyp (vla-get-linetype lay)) "HBFENCELINE8")
(put_linetype lay "FENCELINE8" "HBLinetypes.lin")
((wcmatch (setq ltyp (vla-get-linetype lay)) "HBZIGZAG")
(put_linetype lay "ZIGZAG" "HBLinetypes.lin")
((wcmatch (setq ltyp (vla-get-linetype lay)) "ACAD_ISO06W100")
(put_linetype lay "ONDERZOEKSLOCATIE" "HBLinetypes.lin")
Your question is somewhat strange since your code contains the solution to your problem.
This is how you call a Lisp function with 3 arguments:
To call a Lisp function with 0 arguments you use:
(LAYERCHANGER)
IMO you should move away from your current Copy-Paste approach and get better acquainted with the basics of the Lisp language.
Vbarun means that you want to run visual basic code not lisp.
(vl-vbaload "P:/AutoDESK/VBA/Design Toolkit.dvb") (vl-vbarun "ToolKit")
I agree that i have to let go of my copy-past method. Tho i think its a good way to learn LISP by reading working code and trying to understand it.
But anyhow. What would be the correct way to let this LISP work?
The reason i want to call this part of code seperately, is because the LAYERCHANGER 'command' is going to be put in a whole list of commands that need to be exectued when i enter the command TESTLISP.
Thanks in advance.
Just re read the above because C:Layerchanger is a defun you need to call it the simple way as Roy_043 posted though you may need (c:layerchanger)
old
new
[b](C:LAYERCHANGER)[/b]
[b]
[/b]
Alright, i tried it the right way then.
But when i try to run TESTLISP, i get the message: 'error: no function definition: C:LAYERCHANGER':facepalm:
There was some errors, missing ")" need to initialise list, did the same thing twice.
(defun C:LAYERCHANGER (/ put_linetype linetypes ltyp ltyps)
(vl-load-com)
(IF (= adoc NIL) (setq adoc (vla-get-activedocument (vlax-get-acad-object))))
(setq ltyps '() ) ; LIST OF NIL
(c:Layerchanger)
Edited by BIGAL
@BIGAL:
There is no need to initialize the ltyps list. It's value is already nil since it is a localized variable.
(equal '() nil) => T
Thanks guys,
It seems like the piece of code BIGAL posted fixed the problem. :-)
I was also able to remove the 'C:' in both parts, so the command LAYERCHANGER cannot be executed from AutoCAD but only called by the lisp itself.
Thanks guys! :-)
