I'm trying to get the length of pline in a lisp and wonder if there is a fast way.
i try to change a lisp of area but there isnt getvar for lengthen.
area lisp:
(Command "area" "e" ent "text" "m" pause (* (GetVar "DimScale") S) pause (StrCat "S=" (Rtos (GetVar "area")) 2 2)))
length lisp:
(Command "LENGTHEN" "L" "" "text" "m" p333 4.8 "0" (StrCat "S=" (Rtos (GetVar "LENGTHEN") 2 2)))
ill be glad if someone would help me with this
i'm trying to get the length of just one pline.
i change the line to:
(Command "LENGTHEN" "L" "" "text" "m" p333 4.8 "0" (StrCat "S=" (Rtos (GetVar "Perimeter") 2 2)))
for now it's work for me.
Is this part of a much larger routine?
yes. this part of a much larger routine
and i'm new with the lisp programming
so thanks for the respond and the forum
(vla-get-length (vlax-ename->vla-object (car (entsel))))
Another:
(defun getlength ( ent / par )
   (if (not (vl-catch-all-error-p (setq par (vl-catch-all-apply 'vlax-curve-getendparam (list ent)))))
       (vlax-curve-getdistatparam ent par)
(getlength (car (entsel)))
Another:
Also, this method will work on lines, circle, arc, lwpolylines, 2d polylines, 3d polylines, etc.
