aviatecar Posted October 4, 2016 Posted October 4, 2016 Hello Gurus: I am trying to create a dynamic block for section view. However, when I want the section rotates, one attribute does not follow the path while the other doubles the radius of rotation. Please see attached. Thank you! ChrisDynamic Block Tester1.dwg Quote
SLW210 Posted October 5, 2016 Posted October 5, 2016 Does AutoCAD LT 2017 have the ability to create constraints in Dynamic Blocks? Quote
Ski_Me Posted October 5, 2016 Posted October 5, 2016 The tag for both attributes were the same I changed them to XUPPER and XLOWER. The tag is the name of the attribute, if you have 2 attributes with the same tag in the same block this confuses AutoCAD just change the tags so they are different. Go to block editor and see what I did. You can change them to whatever you want just as long as they are not the same. TESTBLOCK.dwg Quote
aviatecar Posted October 14, 2016 Author Posted October 14, 2016 Thanks you guys for your responses. I was away from that task for a few days. SLW210: I am not sure if it has that feature but Ski_Me's solution works for me. Ski_Me: Thanks for your help! It works! Quote
